Hello
[Attn: Melbourne Skyline Drivers]
I am after two r34's and two r33's for our formal.
Two R34's will be in the middle with the r33's at the front and back.
The four cars will be transporting 2 people each.
The formal will be on November 18th and the location is 81 bay street, brighton. More information will be provided closer to the date.
We are willing to pay:
$60 for each R34
$40 for each R33
$60 for each R33 GTR
$60-$100 for Blue R34 GTR
The 8 of us will meet up at Ferntree Gully. The exact position is still pending.
The 4 cars will have to drop us off and no return drive is necessary.
If possible we would like to prefer reliable drivers which have a reasonable reputation on this forum, after all we do not want to be dropped off in the country...
Drivers must also have a Full Victorian license due to safety reasons.
Please post a picture of your car so we can decide on the colour scheme for the 4 cars.
Thank you
Regards
Patrick
Edited by Rekin
https://www.sau.com.au/forums/topic/85349-need-formal-rides/
  • Replies 96
Stop being too sexes man, what about R32 :D ? Hehe only kidding just a question though, if 34's are being use for transporting.........is it chicks or guy? If it is chicks then i'll borrow me mate yellow R34 and do it for only $30 returned :) .
The amount of people and gender status is still pending as we may decide to have 8 people, (2 people per car for 4 cars). Probably my mates would be more interested in having a ride in the lines than the girls in their limo's.
if paul is doing it ill join the fun i have a an r33 packing a punch contact me on 0421830517 willing to do just for the fule we use so contact me
scott andrew
Edited by Let Me Drive
Thank you all for the quick replies.
Due to Leewah's interest in the formal run we have made some alterations to the run.
We are willing to pay $60 each for four cars.
We would like:
r34 turbo
r33 GTR (Leewah)
r33 GTR
r34 turbo
As we are still waiting for more replies the names and car's may change due to availability. So all R33 GTST's do not worry, we still love your cars and we may still need you ;)
Hope to make this a memorable experience for all :)
Regards
Patrick
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
