  • Replies 714
Posted Images
Garry,
Did you get my PM? I deposit money on Friday, for my order for R33 GTS4 and send you the internet money transfer details via PM.Please confirm.
Cheers.
The shipment was received at Bilstein and deliveries will start tomorrow for guys that have already placed orders. There are quite a few sets in stock, but they will go quickly, so get your orders in.
The standard delivery times are restored;
Springs are usually in stock at Whiteline
Bilstein takes 1-2 working days to machine the additional circlip grooves
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
I PM the con note number as soon as Jamex issues it that way you can track the delivery on the Toll web site.
:( cheers :)
Hey Gary, was just wondering, if someone was to replace ALL of their bushes, what would that involve?
I've already got both camber kits and the caster kit, front and rear sway bars, and pineapples.....i've ordered the springs and shocks off you so once those are in, is that everything changed or is there still more to replace?
you could probably change the original liquid filled cradle bushes. it's a big job though - the whole cradle needs to be dropped. i've been told that it's easily a good couple of hours kinda job. :laugh:
There are no bushes left that wear excessively once you have installed the stabiliser bars, the caster, camber and rear subframe alignment kits.
:P cheers :P
The R33GTST Bilsteins arrived at Jamex today and deliveries for orders placed will commence tomorrow, check your PM's for con note numbers tomorrow.
If you are thinking of getting an R33GTST kit, I strongly suggest that you do it very soon. This shipment won't last long.
:thumbsup: cheers :woot:
I'm thinking of putting everything on the car myself and then getting a workshop to adjust/align everything.
Has anyone else installed a full kit themselves? How easy was it?
good luck with the bushes.
I haven't done it yet but if you've got your suspension apart to put the shocks in it shouldn't be too hard to take out the necessary control arms and castor rods and take them to a pedders or something similar to swap the bushes over. Since you've done the hard work of getting the parts out they shouldn't charge you much to just press out the old bushes and put the new ones in. They may look after you a bit if you say you'll be back to get a 4 wheel alignment in a few hours.
Then just drive down and get your alignment.
Edited by Fry_33
:D cheers :(
Garry, PM sent, still waiting for the con note.
didnt recieve my con note number, but my parts arrived yesterday in the mail. all in good order, everything seem to be there.
just a q's for you SK, what are the spring rates front and rear??
compared to the normal rate??
thanx
daz.
Edited by 85URK
Got my stuff yesterday too..delivered at 8am!
Was just wondering what grooves the shocks should be set at front and rear for the 350/340 settings?
And also, how involved is the process of changing the height later on down the track once everythings installed...is it like completely re installing the suspension?
Will installing springs/shocks affect my camber/caster settings?
good question, i was wondering about the circlip groove height's aswell, i think they are set for 350/340 setting as they are, when they come, but dont hold me to it. anyway SK will answer all our questions lol
Edited by 85URK
I can't seem to find the price listing Gary.
Can you repost the link for it?
Thanks.
Matt
here is the first page link, go down past the first 2 pictures, its after them in the first post.
http://www.skylinesaustralia.com/forums/in...t&p=1547702
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
