i just got a front pair of these shocks revalved for stiffer springs etc, and they are AMAZING.
ive had japanese coilovers (tanabe) before, ive borrowed my mates cheap and nasty HSDs and now ive got bilsteins, they are so much better than anything else ive had.
both more comfortable and handle heaps better
cant wait to take em out to the track!
Edited by salad
if this group buy is still on can i check the availability of the front Hduty swaybar - BNF28 and the rear XHduty swaybar - BNR26X
is there a kit which includes the bushes and links aswell?
PM sent
:no: cheers :D
Hi sydneykid
im interested in these and can i have sum prices inc shipping to melbourne PM me..
-Front & Rear Springs (im looking to lower my car only 25mm front and rear coz i have 19inch" rims and any lower it will rub. so would u supply lower 25mm springs?)
-Front Bilstein & Rear Bilstein Shocks
cheers
bill
SK i have lowered my car quiet abit...
Center of rim to gaurd on both front and rear is 295mm, and im not exaggerating at all lol
I am goin to grab a few bits off you to go with some whiteline stuff i have (mainly after some traction so adjustin the camber as much as i can), is bein that low going to damage anythin (apart from my kit and exhaust.. hahaha)??? I noticed better handlin when it was 10-15mm higher but i prefer the low look.
Shoot, where to start............just a short list of stuf that your are risking;
1. Drive shaft breakage is possible
2. CV joints will wear very fast (they are also soaking up extra power due to the extreme angles)
3. Steering tie rods (front and rear) are under extreme loads
4. Every single bush in the front and rear suspension will wear out excessively fast
5. The strut towers will eventually crack (both front and rear) due to the lack of bump absortion
6. The rear cradle will crack around the upper and lower control arm joints also due to the lack of bump absorbtion
7. You will suffer poor traction, so it won't stop or accelerate anywhere near its potential
8. The front and rear windscreens are stressed members, so they will eventually crack as well
9. Every electronic component is being subject to higher than its design levels of NVH, so they will eventually start to fail one by one
10. Your chiropractor will make a small fortune fixing your lower back problems
That's pretty much the major items, there are quite a few minor ones of course, but I think you get the drift.
:D cheers :(
Edited by Sydneykid
Alright Gary... whats the lowest i can be without stressing the suspension etc too much?? :O Dont tell me 330mm coz thats heaps hahaha
I use camber correction as the first measuring stick as to how much a car can be lowered. When the camber gets grossly excessive, then you know you have lowered it too far. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Using that rule of thumb, 340 mm front and 330 mm rear is a low as I would go, keeping in mind that they handle best at around 350/340. So even at 340/330 you are sacrificing handling for looks.
:thumbsup: cheers :no:
Edited by Sydneykid
SK,
will the shocks work on standard gtst springs? and just to confirm that they are height adjustable? what's the advantage of going to the whiteline springs also?
i want something that i can adjust about 20mm lower, but put back to standard if i need to
but i also want the ride to be comfortable as this car probably won't ever see track work
and finally, just confirming that the price is for a pair? so a set of 4 shocks will be around $1140?
thanks,
Warren
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
