  • Replies 517
ok its been long time since I worked @ Vet.
edG - Russian Blue?
rrrarrage - is it pure breed? or just mixed Moggie
Archie- they are rainbow lorikeet
Peta- thats siameses?
bass junky- Siberian
nah joe her mum is a tabby point... dad was a bitsa her sister is the one with the white nose up there ^^
she looks just like a russian blue with those deep amber eyes tho.. and i love russian blues :)
he he, they sure are, had a crow out there today trying to scab the lorikeets food, was gonna take a close up shot of it, but shit it just looked too big and scary.... really need a digital slr so i can get some good close up shots of it as my old slr is busted...
edG - Russian Blue?
i have no idea what he is. he was a stray. so probably mixed. don't mess with him, he's from the bad hoods of melbourne.
nothing special just a few quick little shots i took in a moment of boredom. didn't have my tripod with me for the car shot so it's not as sharp as i'd like .... but i'll be taking a few more shots at my work car park later... the lighting is interesting in there...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
