Hi,
Just put some heat wrap on my dump pipe, the stuff that kinda looks like fiber glass. Anyway after the first drive or so there was some smoke coming from the tape that smells like Ski wax :huh:
I figure this will go away after a couple of drives but just wanted to check if anyone else has had this problem?
https://www.sau.com.au/forums/topic/85695-heat-wrap/
when you wrap it it's a good idea to wet it as you wrap. ie wit a section say 8 inches long, wrap it around and so on. then once it's all tight and secured let it dry. then paint it. will give a good result that way. and yes it will smoke a little and smell at first but it will go away.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-1552836
  • 2 years later...
Sorry to bring up an old thread.
Im about to use heat wrap on GTR dump pipes. Beer Baron can you tell me the theory behind painting it and what type of paint you would use?
I plan to use metal cable ties. Cheers for the tip of wetting the fabric, i guess it will keep things in place until it gets secured properly.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654321
i brought up this very topic with my mechanic a few days ago. he has worked with nissan for seven years , and in the renault racing team in europe for about 3yrs.
in theyre racing cars he used to soak the heat wrap in water then install it, this would mould in shape. BUT it would smoke for ages after it.
eventually it should go away.
p.s i asked about the pipe cracking issue. he said its 'bullshit' on a renault 24hr le mon race he reckons that there was no problems.
and i would believe him....he has tested it.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654682
Im curious to know why to put some paint on the heat wrap aswell, i have never heard of that being done.
Im not trying to say i know more than a mechanic or anything but i still have worries about the heat wrap cracking the pipe quicker than without the wrap. The way i see it, the wrap holds in the heat which doesnt allow the pipe to radiate the heat therefore putting more stress on the welds. (which i have seen done before) could have just as easily cracked if it was crappy welding anyway.
having a race car in a 24 hour race shouldnt do much damage because its only going for 24 hours and the car is sitting mostly at the one temperature. compare that to everyday driving where the car has to last years of heating up to big temps and cooling down to nothing on nearly a daily basis I would be worried heatwrap would reduce the life of the wrapped part.
Im about to put some heatwrap on my dump pipe. so ill find out myself
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654835
paint the pipe. Cure it. wrap the pipe evenly (very important) and then paint over it.
The idea is to prevent moisture build up when cold and also does a little to protect the wrap.
Even application of the heat wrap is important so as to avoid hot/cold spots.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655171
Yeh painting it helps seal it from moisture.
Regarding the cracking. The way i look at it its temperature differentail and rapid cooling that hurt the metal more then the ultimate temperature you run it at. When wrapped it ensures that the metal cannot cool quickly or be splashed with water on wet roads.
I wrapped ahd HPC coated my manifold and never had problems for several years. One time i had the manifold off and i was lazy and too cheap to re-wrap it, just running a heat shield. Since then i have had a few problems with cracking. Whether that is a coincidence as the manifold is obviously older and by nature more likely to crack as its older...or the more rapid cooling hurts the metallurgy of the steel and weld. Since the welds lack proper penetration they are the weakest point so most likely to fail at that point.
Anyway, thats my take on it. I woudl ceramic coat and wrap it. Ceramic coating by itself does next to f**k all from a temp standpoint...they work well in combination with one another. Just make sure you wrap it evenly. Leaving sections exmposed to air introduces the whole temperature differentials again which leads to internal stresses and fatigue cracking
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655247
lol sure mate. redlining every gear for 24hrs doesnt do any damage, and it sits at 1 temp.
WTF!!
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655378
WTF!!
i think he means its at a more consistant temperature then a road car which is probably true
cars bone cold, start it, drive 20mins, get hot, cools down, etc etc
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655444
Haha i dont think i explained myself right. I meant to say it sits at 1 temp being really farken hot for a long period of time so it gets hot and stays hot and doesnt have much chance to cool down and contract. compare to a street driven car where it heats up when driving, then goes cold when you stop. then heats up when u drive it again. therefore the metal would expand and contract more making it more prone to cracking. Ill stop now im sure im digging the hole even deeper.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655445
I have known a few examples of heat wrap leading to fatigue and cracking, both instances were caused by uneven wrapping and no paint being applied. One example was my brother's car , he was a slack bastard and there were gaps that allowed condensation in. I re-wrapped his next set of extractors and he never had problem again.
I have heat wrapped lots of exhausts inc. rotary exaust pipes without any issues for many years. I've done this to so many cars including mates and never had any issues.
The absolute rubbish people go on about cracking is due to people not doing things properly. You notice non-wrapped stainless manifolds are far more prone to it. Hell even Tomei supply heat wrap with thier RB26 replacement stainless turbo manifolds, I wonder why? Maybe they want you to come back and buy more manifolds off them when they go and crack on you? Stupid!
Edited by rev210
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655955
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
