I'm curious into whats involved in a dry sump set up.
I don't know enough about them to weigh up if it's worth doing.
I'm slowly building up a 26/30 thats estimated at 600hp going into a 240Z that will see some weekend street and track driving.
How do they work?
What does it mean by 4 and 5 stage pumps?
Can a normal RB sump be modded to suit a dry sump?.
What price range would I be looking at for a simple setup?
Does anyone have pics and experiences using dry sumps?
Thats all the questions I can think of atm.
Edited by retrotec
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/
If you cant do any of the work yourself it will cost you around 6g. If you can make everything yourself and I mean everything brackets, custom aluminium machining filter setups etc it will still set you back around 2.5g with new parts. THere is alot of work involved to do it correctly, and not for someone to take on that hasnt had experience with oiling systems before.
4 stage menas there is for drive cogs inside the pump. 3 for scavenge and 1 for oil pressure, 5 means there are 4 scavenge and 6 is 5 scavenge etc. They work as a vacuum pump that draws oil out of the engine under vacuum into the pump then the oil is pumped back out under pressure to an oil reserve(this is the scavenge). the oil enters the reserve at the top and fills and pressurizes the oil in the tank and has an oil supply line (fromt the bottom of the tank) back to the pump on the pressure in side ( the first stage ie. pressure). this oil is re pressured through the pump and goes onto your engine. A normal sump can be modded to suit dry sump. I have pics of them setup on v8s and experience but I havent done my rb series yet and that is on serious back burner, not a priority, so sorry no pics.
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1557879
This is a Peterson 5 Stage dry sump system as used on a V8SuperCar
As you can see it has 4 scavenge stages and 1 pressure stage.
This is the tank design we use, it holds 8.5 litres plus about 2.5 litres in the lines, pipework, cooler and filter.
If you shop around there are plenty of used dry sump systems available. For a GTR you would be looking at a 4 stage system (scavenge, 2 sump, 1 cylinder head and 1 pressure). I bought one recently for just under $2K complete, pump, belt pulleys, fittings, lines, tank and breather. That $2K is about what an aftermarket RB26 pump and adaptor ring would have cost. I used the standard aircon bracket to mount the pump to the block. Bit of fabrication but not much.
As well as perfect lubrication we picked up around 12 bhp from removing the oily mist from the crankcase (stops the crank hitting it on rotation) and around 8 bhp from running a partial vacuum. Also the cam covers no longer fill up with oil, which lowers the CoG, the tank is mounted in the boot with the filter and the cooler under in the airflow. This moves around 15kgs from the front of the car to the rear for improved weight distribution.
Hope that was of some help
:P cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1557956
SK, is $2k really representative of the true cost of setting something like this up?
Does it include the cost of modifying the sump? What would installation and fabrication cost if you weren't able to do it yourself?
IMO dry sumping is right up at the pointy end of the hardcore scale (ie serious race cars).
Where can you buy these things second hand and where can you get them checked out?
I've heard of a few people buying ex race car stuff from the US, can't point you to an exact place tho.
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1559777
Sorry for the question - but im assuming you would require alot more oil for this setup?
Don't apologise, read, esp. SK's post you might learn summin. :P
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1560245
No, because alot of the oil cans have heaters built in to them, to allow instant warm-up.
Although I can recall SK boasting he can do a dry sump for $500, $2K is getting more realistic.... but $4K is a more likely figure.
Two pics showing some of the pre-heaters available. There are the electric blankets going around the outside of the can, as well as a big probe that sticks up through the bottom to about halfway up the can.
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1560266
I would never do one as a kit for a customer to fit themselves, there are to many variables when dealing with inexperienced people on important things like oiling systems. If you where to do a kit there is no way you could it for less than around $4 with all the brackets, sump mods, lines fittings, filter setup etc. Add to this there are a few approaches to doing it on a rb series, with a few of them not being very good....
Buying second hand is risky but it can be done, try ebay, the thing is they still go for pretty good money, plus shipping to Oz is around $120 on the last dry sump pump I got sent, and if you get it here and its no good you have to send it back to the states for service around $200-300 plus shipping both ways. It adds up!!!!!
I think when SK said 2k he meant parts no labour or fabrications. The sump mods alone are worth around $500 if you take it to a metal worker more from performance shops.
Retro there is no scavenge from the sump to the pump, there is pressure in and this is basically your oil supply line from the tank. IF people want to learn a little more general info about oiling systems go to moroso.com or petersonfluidsystems.com
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1560318
excellent. i was going to atempt to do thes conversion but i wanted to retain my a/c.
if there is an engine that needs a drysump it a rb26.
instead im making a 10 litre baffeld wet sump. $60 for the alloy and $200 for setting up the diff(gts4 donor sump)
but i would be VERY interested in pics etc about your setup. ive spent hours on hours searching the net for gtr specific setups. and got ZIP!!
but yes all the nascar ebay shops seem to be the go for all the seconhand stuff.etc
-14 lines and stuff and pumps and oil tanks.
also some good pics on how to set up the innards of a dry sump oil pan.
im looking forward to seeing the setup.
ps. i understand if you want to protect your har earned r and d. :)
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1561273
just run a jun oil pump im running one in my car making 1068rwhp
available from croydon or the trust oil pump available from autobarn
I didnt think the problem was a result of the pump, but rather oil starvation at the pickup during high lateral G's.
Excuse my ignorance but how much of this problem could be fixed (for occasional track use) by increasing oil capacity and adding some strategic windage (sp?) in the sump. Is there also a problem with oil gathering in the rocker covers and not making it down to the sump?, if so can additonal (external) lines be added between the sump and head.
PS - I realise in a dedicated track car the dry sump would be a better option, but many of us are not that serious and want a weekend - tack/street/drag/drift(?) car.
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1561937
A wet sump done correctly will provide a 95% perfect result, however it cant make you horsepower, and sometimes packaging a good wet sump it a problem due to ground clearence. For a street car a dry sump is overkill. I have made three custom wet sumps, one was 11 litres, the other 2 are 7.5-8 litres, I also make a custom trap door system for the inside. To be honest I dont think many of us could dirve our cars hard enough to warrant anything more substantial than a good wet system, the advantage on the dry sump as I see it is the small horsepower gains.
Heres some pics
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1563590
Heres some pics
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1563650
Heres some pics
https://www.sau.com.au/forums/topic/86055-dry-sump-set-ups/#findComment-1563658
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
