Yes or No?
59 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I've still got mine. There really isn't much point in taking it out unless you wanna hide a set of fuel pumps in your boot.
You'd be wiser having it in there just incase you find yourself with a flat even though I wouldn't trust my life to them
. plus worse case scenario is it actually acts as a good way to absorb a crash in the rear-end if some dero gets distracted by how nice your car is and forgets to hit the brakes.
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1563188
I'd like to remove mine but I've had to use it once.
Although without a toolkit (I was lucky and had one on me at the time) there's no point me having it there. I might remove it :P
Doesn't the R33 have the little toolkit behind the panel on the left of the boot ala R32?
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1564163
i dont have one in my gtr
it didnt come with a jack, and i figure if i cant jack the car up, i cant put a spare tire on, so no point having the spare either
you can buy those cans of stuff you spray into the tyre if you get a flat, that or dad can come rescue me
Edited by lang
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1565140
Yeah, the space saver is in there, although it wouldn't have helped without the tool kit that is supposed to be in there. Only the jack was there, no wheelbrace or jack handle. Took it back to the importer and he checked every Skyline he had and none had theirs either!! Seems they are a hot item in Japan????
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1570508
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
