http://www.carsales.com.au/pls/carsales/...rch_distance=25
seems way to cheap for that many mods? kms are not very high for that year.
I doubt you could import somthing with that many mods for that price. I must admit I havnt looked at r34 prices in japan recently.
Edited by tdawg
At the bottom it says you have to pay extra for the mods :)
Someone should call that guy and tell him that in Japan '99 R34 GT-T Turbos cost A$34,000 + ORC NEW...
Edited by Rezz
Rezz, you are in for the shock of your live when you see the prices of a half decent import over here :)
I know... it's gonna be almost like reverse culture shock :(
Don't get me wrong, theres shipping and a profit margin thats gotta be added onto goods sold in AU, but I've been scratching my head ALOT lately the more I check out the SAU state forums... I mean $1,200 for a Japanese no-name cat back exhaust? $900 for shitty used Tein coil overs? Now this $35,000 R34 4 door?
Hmmmmm... :P
"Pioneer Double Din (MD/CD), Quicktrack alarm. Z32 afm, HKS 2535 Turbo, Apexi Injectors, Hawk Brake Pads are available but they are not in the car yet. (These stuffs will be given for an extra cost)."
if u look carefully, everything has a comma after it, cept after the alarm. so prolly the z32, HKS 2535 Turbo, Apexi Injectors, Hawk Brake Pads are only avaliable at an extra cost for he's also selling these parts on the forums too.
u jus have to look here:
http://www.skylinesaustralia.com/forums/in...showtopic=86191
