  • Replies 239
Posted Images
sk
none of the links to pics and details on 1st page are working! can you please fix them?
cheers
simon
Hi Simon. not sure why they stopped working, some server changes perhaps. They seem OK now.
:P cheers :)
all good now :thumbsup:
just a quick question regarding rear camber adjustment, i run my car with tyre just above the guard front and rear so need to pull a fair whack of camber out of the rear wheels. apparently you can use 2 rear camber kits to double the effect. how much positive camber will i be able to add with 2 kits installed?!?
im going to get some castor bushes regardless and already have installed the subframe bushes and have a whiteline front camber kit sitting at home ready to be installed. just need to know if the rear camber is going to be adjustable enough to suit my application or if i should just go with rose jointed fully adjustable items.
cheers
simon
Gary, I simply need the following. Can you confirm the prices? Please provide bank details (via PM) so I can transfer the funds..
KCA336 Front Camber kit $183.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
Please PM
Cheers
Pete (BNR32)
all good now :)
cheers
simon
Hi Simon, the rear camber kits each add 0.75 degrees of positive adjustment, plus the 0.25 of the standard adjuster. But that's the minimum compared to brand new bushes. Since you have been driving an R32 (14 to 18 years old) around at a such a low height, chances are your bushes are far from new and severely distorted. I have seen as much as 3 degrees change in those circumstances, and that was in a car where the bushes looked OK.
Having done heaps of Skyline camber correction myself and sold over 120 kits, no one has reported not being able to achieve the recommended alignment settings. What may stop you is tyre contact with the guard.
>_< cheers :D
Hi Gary, can you please provide bank details so I can purhcase the following (BNR32):
Please PM
Thanks
you have convinced me :D good work
tyre contact with guard is going to be a problem, but im rolling guards and fitting 235's instead of 255's to help with that
will get back to you soon regarding the order
cheers
simon
:) cheers :P
  • 1 month later...
Hi All
Matt here
To Anyone who could not get through, I am now answering PMs and all questions for Gary the best I can. With the new business extremely busy, we have been flat out, however gary is off on Holidays to the USA next week for 5 weeks. This does not mean that sales will hault, as I will personally be looking after all sales and enquiries from this point on. For anyone with more technical questions, there are some I can assist with, but any that I can not will be forwarded to Gary.
So please, PM me (I will check the GB threads when possible, but PM is best - I will supply an email address and a phone number for me)
Cheers
Matt
Matt brought a full kit for my gtr32 and had some problems with the rear camber kit (KCA-347) as some of the bush's were split as soon as I opened the package
tried to pm but got no response if you could pm with a phone number or email address that would be great
cheers
  • 1 month later...
Quick question: what is stock like in the lead up to Christmas?
Cheers,
Lucien.
Flowing.
I can pretty much have anything, anywhere, in 5-10 working days - had a few hiccups this week for some guys, but 5-10 days.
My only dilema is stagea front springs...
Flowing.
Great thanks. Just need to wait for my tax return to come through. Given I have some Noltec replacement sub-frame bushes, I assume there would be no gain from pineapples?
Cheers,
Lucien
Cheers,
Lucien
I believe it is basically the same sort of kit
Hey SK, i was wondering if you could help me out, I'm after a set of GT-R swaybars to suit my HCR32.
I was after:
x1 28mm Front Adjustable Swaybar
X1 24mm Rear Adjustable Swaybar
I have also sent you a PM in regards to the same thing.
Thanks,
Tim
I bought a kit several months ago and thought I write back here with a bit of a review/update.
I ordered the suspension kit around April, the standard kit with Eibach springs and Bilstein coil over conversion. I had the kit fitted in a day by eastcoast suspension. I can highly recommend them.
My initial response to driving the car home from eastcoast was one of total amazement. I just couldn’t believe how smooth it was. No more smashing my back over speed humps.... I even chose to drive up Parramatta road and it felt like the road has been resurfaced. Amazing.
So on the road, my GTR was perfect. But what about the track?
Well I got the Eibach springs coil over kit so I could play with the spring rates for different tracks. My first outing at eastern creek saw me drop three seconds off my previous best time, with no other changes to the car. The car felt a whole lot better. But I wanted to squeeze a bit more out of her, and so I put some stiffer Eibach springs in to make her hold a bit better and made some minor adjustment to the front and rear toe and camber to suit EC and instantly dropped a couple more seconds. I believe I would have dropped more time because my front right tyre had a slow leak which I worked out was dropping about 5psi every 8-10 laps. By the time I worked it out what was going on with it, the track day was over.
1:58 old suspension.
1:55 new suspension.
1:53 changed springs and minor adjustment.
Once home, took the stiff springs out and put the standard ones in. good as gold!
Sk, I owe you a case. PM me your work address and a case of Coronas is on the way!
Good to hear
May I ask what spring rate you went to?
3 seconds with only a suspension change is good.
5 is awesome!!
SK Snr is less of a beer drinker I must warn... Me on the other hand...
Hi SK,
I bought some bush's previously and am now looking at shocks and springs. Have you still got sets available?
Also I know postage would be free for this order, however I would prefer to collect them in sydney. Is this possible?
Thanks.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
