  • Replies 239
Posted Images
sk
none of the links to pics and details on 1st page are working! can you please fix them?
cheers
simon
Hi Simon. not sure why they stopped working, some server changes perhaps. They seem OK now.
:P cheers :)
all good now :thumbsup:
just a quick question regarding rear camber adjustment, i run my car with tyre just above the guard front and rear so need to pull a fair whack of camber out of the rear wheels. apparently you can use 2 rear camber kits to double the effect. how much positive camber will i be able to add with 2 kits installed?!?
im going to get some castor bushes regardless and already have installed the subframe bushes and have a whiteline front camber kit sitting at home ready to be installed. just need to know if the rear camber is going to be adjustable enough to suit my application or if i should just go with rose jointed fully adjustable items.
cheers
simon
Gary, I simply need the following. Can you confirm the prices? Please provide bank details (via PM) so I can transfer the funds..
KCA336 Front Camber kit $183.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
Please PM
Cheers
Pete (BNR32)
all good now :)
cheers
simon
Hi Simon, the rear camber kits each add 0.75 degrees of positive adjustment, plus the 0.25 of the standard adjuster. But that's the minimum compared to brand new bushes. Since you have been driving an R32 (14 to 18 years old) around at a such a low height, chances are your bushes are far from new and severely distorted. I have seen as much as 3 degrees change in those circumstances, and that was in a car where the bushes looked OK.
Having done heaps of Skyline camber correction myself and sold over 120 kits, no one has reported not being able to achieve the recommended alignment settings. What may stop you is tyre contact with the guard.
>_< cheers :D
Hi Gary, can you please provide bank details so I can purhcase the following (BNR32):
Please PM
Thanks
you have convinced me :D good work
tyre contact with guard is going to be a problem, but im rolling guards and fitting 235's instead of 255's to help with that
will get back to you soon regarding the order
cheers
simon
:) cheers :P
  • 1 month later...
Hi All
Matt here
To Anyone who could not get through, I am now answering PMs and all questions for Gary the best I can. With the new business extremely busy, we have been flat out, however gary is off on Holidays to the USA next week for 5 weeks. This does not mean that sales will hault, as I will personally be looking after all sales and enquiries from this point on. For anyone with more technical questions, there are some I can assist with, but any that I can not will be forwarded to Gary.
So please, PM me (I will check the GB threads when possible, but PM is best - I will supply an email address and a phone number for me)
Cheers
Matt
Matt brought a full kit for my gtr32 and had some problems with the rear camber kit (KCA-347) as some of the bush's were split as soon as I opened the package
tried to pm but got no response if you could pm with a phone number or email address that would be great
cheers
  • 1 month later...
Quick question: what is stock like in the lead up to Christmas?
Cheers,
Lucien.
Flowing.
I can pretty much have anything, anywhere, in 5-10 working days - had a few hiccups this week for some guys, but 5-10 days.
My only dilema is stagea front springs...
Flowing.
Great thanks. Just need to wait for my tax return to come through. Given I have some Noltec replacement sub-frame bushes, I assume there would be no gain from pineapples?
Cheers,
Lucien
Cheers,
Lucien
I believe it is basically the same sort of kit
Hey SK, i was wondering if you could help me out, I'm after a set of GT-R swaybars to suit my HCR32.
I was after:
x1 28mm Front Adjustable Swaybar
X1 24mm Rear Adjustable Swaybar
I have also sent you a PM in regards to the same thing.
Thanks,
Tim
I bought a kit several months ago and thought I write back here with a bit of a review/update.
I ordered the suspension kit around April, the standard kit with Eibach springs and Bilstein coil over conversion. I had the kit fitted in a day by eastcoast suspension. I can highly recommend them.
My initial response to driving the car home from eastcoast was one of total amazement. I just couldn’t believe how smooth it was. No more smashing my back over speed humps.... I even chose to drive up Parramatta road and it felt like the road has been resurfaced. Amazing.
So on the road, my GTR was perfect. But what about the track?
Well I got the Eibach springs coil over kit so I could play with the spring rates for different tracks. My first outing at eastern creek saw me drop three seconds off my previous best time, with no other changes to the car. The car felt a whole lot better. But I wanted to squeeze a bit more out of her, and so I put some stiffer Eibach springs in to make her hold a bit better and made some minor adjustment to the front and rear toe and camber to suit EC and instantly dropped a couple more seconds. I believe I would have dropped more time because my front right tyre had a slow leak which I worked out was dropping about 5psi every 8-10 laps. By the time I worked it out what was going on with it, the track day was over.
1:58 old suspension.
1:55 new suspension.
1:53 changed springs and minor adjustment.
Once home, took the stiff springs out and put the standard ones in. good as gold!
Sk, I owe you a case. PM me your work address and a case of Coronas is on the way!
Good to hear
May I ask what spring rate you went to?
3 seconds with only a suspension change is good.
5 is awesome!!
SK Snr is less of a beer drinker I must warn... Me on the other hand...
Hi SK,
I bought some bush's previously and am now looking at shocks and springs. Have you still got sets available?
Also I know postage would be free for this order, however I would prefer to collect them in sydney. Is this possible?
Thanks.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
