  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
At a Kazakh home the most honoured guest, usually the oldest, is traditionally offered a boiled sheep's head on a beautiful dish as a further sign of respect. National customs forbid young people whose parents are still alive from cutting the sheep's head.
*charming* lets all visit kazakhstan!
Arabic coffee will normally be served continuously during social occasions. To signal that no more is wanted, slightly tilt the cup when handing it back, otherwise it will be refilled.
*Jordanians are obviously caffiene addicted*
The Jewish religious day is Saturday – Shabbat – and begins at nightfall on Friday until nightfall on Saturday. Most public services and shops close early on Friday as a result.
See if i was jewish i would be home by now *sigh*
