  • Replies 333
stock turb a 33-t does 200 tops.
stock turb a GTR can get to near 300  So its believable easily.
NEO runs more compression than non-NEO RB25. Thats why 14psi is limits :D
Thats what i think :)
The stock R33 turbo IS a 0.63 A/R
The stock GTR turbo is a 0.42 A/R
A gtr turbo on it's own cannot get 300, there is a pair of them don't forget.
As with the compression, 14psi boost is not it's limit. You are right about fuel being his problem but these engines will take more than 14 psi. I have sent them over 18psi on stock internals with no ping whatsoever. It just needs to be tuned properly.
The better option would have probably been to go for a true GT30R on a highmount with external gate. You will achieve massive results provided you can keep the fuel up to it. A water methanol injection system will help you out with your pinging problem as you are effectively increasing the octane rating of the fuel.
Then look at an electronic boost controller to fix the weird boost problems, he said he'd just stick a 15psi actuator on there to make it easier again..
Im using a dual stage Hybrid brand EBC, and can recommend it. Cost f-all really. No spikes, doesnt go past what I tell it to go up to, etc. Good value for money, Mafia.
With a big upgrade like you've got I would have thought it'd be wise to have a solenoid-controlled boost (although I am a newb @ turb's so my opinion counts for jack s_t).
Hhhm, crating drums of petrol isnt a bad short-term solution, just initially very expensive. Maybe worth looking into to help out in the meantime, whilst you're waiting for new higher Ron petrol bowsers in your area!! :D
Keep at it mate, well done, and I hope I never run into headf* problems when I have the $ to do my gt30-hiflow upgrade (18months away). <_<
Brendan
I'd consider shipping drums up but I can't due to the fact I have no where to store it. If I did, I would certainly do it.
I'm not a guy with heaps of cash either so yeah, I'll be looking for the most cost effective solution.
One of my mates runs a Supra with 375rwkw, and he said that he got the last 100hp with the water methanol kit. Stopped all pinging.
I guess thats all we can do for now until we get some fuel which I highly doubt.
The 14psi thing, if you read what i quoted, was Bass Junky's limit for his NEO using the GCG hi-flow before pinging was an issue due to the higher compression of the NEO vs the non-NEO RB25 (did i just repeat myself?)
Its not a question of how much out-right PSI you cna screw into the thing.
Its the airflow
So are you saying that because his turbo isnt "true", meaning high-mounted and he isnt using an external gate that he isnt getting the best results?
Considering that 95 fuel is being used and such low boost the results themselves are pretty damn good.
Fuel/meth and boost with a .63 and it'll be up into the 250 no worries
And thats pretty much as far as its gonna get, maybe 270 as a peak
A GT30 with the older wheel really isnt doing a great deal other than hanging on for the ride with 14psi on his motor
Thanks so much for the info, but what do you mean by this?
Do I have the older wheel?
ye, discopotato noted it also.
Its the T04S wheel, not the GT trim one.
T04 is the 7-blade and the GT is a 6-blade comp wheel.
Read disco's posts so far in this thread, he's right on the money with what he says :D
I'm not saying he won't get what he has set out to achieve with the setup he has. I am saying he will achieve more with the other setup and won't have exhaust restriction to worry about.
I don't believe the exhaust manifold poses a problem up until ~300rwkw where it literally hits a brick wall and will not allow any more power to be made.
There's 2 RB's running around Adelaide with the stock log, both appear to hit a brick wall ~300rwkw.
One of the turbo's is a GT3540 .82 internal gate running ~18-19psi making slightly over 300rwkw on a rb30det, the other is a GT3040 running an internal gate making ~300rwkw on a rb25det. Both are running cams, running on the same dyno that is known not to be conservative.
BUT, there is gains to be had by using a nice manifold. More ignition timing due to less uneven cylinder reversion. One person I know of picked up 20rwkw (306 - 326rwkw) by changing the exhaust manifold @ the same boost.
Edited by Cubes
I agree it is the fuel.
When mine was dead stock it used to ping slightly on 95RON BP.
The BP's started getting 98 Ultimate and I was able to dial in 17degree's and up the boost to 12.5psi without ping.
I also agree it's fuel but what's stopping him from just injecting more of it? Back up the timing a degree or two and up the boost. 98 and 100 ron fuels haven't been around forever and people didn't seem to have any problems back then
The fuel does play a big part but I do think its its simply a combination of things. It needs some good dyno time to sort them out.
Fuel, Cam timing, afr's, ign. timing and boost.
Mafia... Do a map trace and take note of what load points are used, then let us know what ignition timing is being run through out the rev range at WOT.
Edited by Cubes
hang on, one sec your saying he needs to high-mount and ext gate the turbo.
but now its the fuel thats causeing the problem?
Its simple, whats stopping him? fuel!
No point backing out too much timing to screw boost into it.
The fuel needs to be sorted before those sorts of things get fiddled with
98/100 hasnt been around that long... maybe, but niether has higher compression ratios
I never said that. Go back and read my post. I was saying that he would, in general, achieve higher results with that type of setup. I wasn't saying that was the cause of his lack of power at the moment.
here is the Ignition map...pretty pathetic hey... It gives me a maximum of 20 knock on a hot 35 - 40 degree day. NOt sure on the WOT positions, but you can kind of see it on the fine tuning on the p13 and p14 rows. I don't think it gets any lower than that.
timing.htm
The cruise areas look like they have been tweaked.
This could possibly be the reason for poor fuel economy.
I'll have a look exactly how much they have been tweaked. :P
Too much ignition timing can cause poor fuel economy also.
Edited by Cubes
thanks, and let me know if I could sneak anymore in the lower range safely.
I could add 10 more degrees and see no knock but I dunno if thats dangerous or not. I dunno if too much advance is good or not.
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
