I know the twin turbo 3ltr sequential twin turbo supra has a lot of potential. But I was just wondering if anyone knows what rwkw are achievable with the following mods
- After market cooler
- Power FC or equivalent
- full exhaust system from turbos back.
- boost increase with stock turbos
From reading these forums and from personal experience these mods on a RB25 with 10-12psi of boost ~200rwkw seems to achievable. I know the supra will make a lot more power than this but how much more?
Edited by Munna
https://www.sau.com.au/forums/topic/90052-toyota-supra/
  • Replies 46
Well.. when we were at the dyno day with OCAU a supra running pretty much the same setup except it was running a SAFC2 and a boost controller I believe.. he reeled off about 240kw..
Thanks thats about what I would have expected anyone else? What 1/4 mile times would a supra with these mods and a good suspention setup get?
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1623994
My brother has a '95 Supra RZ with those mods, plus a Trust pod filter, Bosch 044, AVCR and a Malpassi fuel pressure regulator and is making 272rwkw at 14psi. He could be making a little bit more, but needs a new dump pipe.
"They taste like burning!"
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1624554
The dump isn't stock; it's a 3 inch dump. But he was told that a 3" dump was too large for the stock turbos on a Supra as the wastegate can't control the boost properly (needs the back pressure). So he's had a restricter put into the dump until he gets a new one.
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1624659
Got a friend who got there 1996 TT (6spd) Supra dynoed with the following setup:
1. Aftermarket Front Mount Intercooler
2. Stock Air box/Turbos/Boost setting 10psi or there abouts
3. Catback- OR turbo back exhaust (unsure)
4. 18" rims.
result:
214rwkw at unigroup.
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1624706
2JZ-GTE into an R33 is stupidity in my opinion. 2JZ with the 6 speed costs an absolute fortune, and an RB26 can make similar power. If you really want the BIG CUBE straight six, you could probably build a killer RB30DETT for less than a 2JZ engine swap. The cost of installing a 2JZ would be phenomenal.
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1624976
Keep a Supra engine in a supra, and an RB in a Skyline..
If you want extra power in a Gts-t.. go and buy an R32 GT-R than you'll even it up.. what a skyline lacks sometimes in raw power, it makes up for round the corners.. ATTESSA.. and a couple of other areas..
Personally I would love a Supra TT - but for 40k i'd be hard pressed to not buy a R33 GT-R..
They are definately quite a nice car.. I love the look of them.. so sleek.. with a set of rims, lowered with no wing.. droooolling..
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1625025
Thanks everyone I know that the supra is quicker over the 1/4 than the r33 gtst from the factory.
How would a R33 GTS-T fare against a the supra both in street trim at this level of modification assuming they both have a decent suspention/tyre setup. Keeping in mind the supra weighs 200kg's more.
I know that the skyline is capable of high 12's what can the supra do?
https://www.sau.com.au/forums/topic/90052-toyota-supra/#findComment-1625140
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
