  • Replies 183
Posted Images
I don't have the shadow chrome 18's any more (too much unwanted attention) and the ones on the rear are my drift/fun rims!
Washed my car today so i thought i'd go for a quick drive to my favourite spot and take some more piccies with the rims i use majority of the time!
sexi320205wg.th.jpg sexi320287lq.th.jpg dsc003741dr.th.jpg dsc003701ki.th.jpg
(new pics added!)
Edited by mr_rbman
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
