some may be aware i bought myself a stagea a short while ago(to stop myself spending more $$ on the 33 :D ) and right on xmas eve as i was on my way to work,(less than 30m from my work) a dickhead flew round the corner through the lights and hit me in the ass end while i was stationary waiting for someone else to reverse into a spot, i was pissed off! ;) anyway upon inspection not much damage mainly to the black plastic strip on the bumper, and the rear reo bar slightly bent in and some other minor scratches, pretty much rooted the other blokes car/wagon, it has ended up working out to my advantage after persuading the insurance assessor it would be too costly to source an original bar(althogh it is minor damage) has agreed to sign cheque over so i can buy aftermarket kit (and i have done, it is waiting for me at the depot to pick up, its a freeway dolphin full body kit+ planning some other mods, but not heaps ;) ) so could of been a lot worse, im also having a tow bar built so the stagea can tow the 33 down to pwr 11 cruise and other upcoming events
Edited by madaz R33
sounds good mate, just installed my new el-dials.
also have side skirts sitting in my garage waiting to be painted lol heres a pic that i somehow took when i got the sides just sitting on the side..
Been making some progress with my locost project, sourced some yamaha R1 motorbike shocks for the suspension, at $60 a piece posted from america they work out to be much cheaper than the propper $300+ per corner stuff. Mounted them konegseig style in the rear
Now just chasing more parts so I can design/build the front steering & suspension. Then I can get my engineer to have a look, and I will find out if I can get it road registered ;)
This is what's been going on in my world. You can read it here
www.johnbriggsracing.blogspot.com
[/quote
i just got my fully sick bov on... haha posing parts..... yes but i pulled the gay aftermarket jap spec cd player out and putting my new one in and sub. getting my steering wheel re done. should look pretty tidy.
hey trent. dials look sweet. if you dont mind me asking how much? and how did u pull the old one out? wouldnt mind getting some as the stock ones are a tad boring
What ECU you running? I saw the clip on youtube before, looks good, and sound like the passenger was a little nervios into the first corner :laugh:
Not sure on the ECU, it's an R32 that's been tweaked by Tomie I think. Was going like a train!! He wasn't to bad, it was his first time on the track :mad:
It's all stripped and cleaned, measure up tonight and order bits tomorrow. :glare:
Not sure on the ECU, it's an R32 that's been tweaked by Tomie I think. Was going like a train!! He wasn't to bad, it was his first time on the track :laugh:
looks like you need to invest in one of stus incar cams :mad: but seriously your camera man did a good job. seccond corner looks like a hand full.
have you rebiult many motors wogboy? ive got an rb25 waiting for a rebiuld up here you wont mind if i send it down.
looks like you need to invest in one of stus incar cams :) but seriously your camera man did a good job. seccond corner looks like a hand full.
You'd have better luck if you send it up seeing as he lives a little higher than you Damo :rofl:
That car of yours must be close to going now???
Drained diff oil and it wasn't too bad considering it was over 2 years old :ermm:
You'd have better luck if you send it up seeing as he lives a little higher than you Damo :)
Drained diff oil and it wasn't too bad considering it was over 2 years old :P
your not wrong. its ok when i can get near it. to much other after hours work to do haha. is very close indeed but im nto going to say when just yet.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
