Well I have decided to sell the R33 at the end of the year, because I'll be looking to buy a house.
Just letting everyone know in advance, incase they are after parts, I will be taking the car back to stock as modded cars are too hard to sell for what they are worth.
Parts that will be available are as follows:
Z32 AFM & Plug
HKS GTRS Turbo
Nismo 550cc Injectors
3" JJR Bellmouth Front/Dump pipe
Kakimoto Regu 06&R Cat Back
Apexi PowerFC with Commander and Electronic Boost Controller
Splitfire Coilpacks
Nismo Fuel Pump
Cold Air Box
HICAS Lockbar
Will post up closer to these parts being available. Just giving a heads up, as I know what it's like when you buy brand new parts and the next week good second hand parts become available.
Start saving! :down:
31's driveable and seeing the odd short trip, lots of little jobs left though. Like paint/fit front bar, lip, roll and paint both rear quarters and paint both front guards; pull leaking front pipe off and get welded up ('perfect condition' secondhand BATMBL dump I bought for a fair amount of dough leaked from the word go around the wastegate pipe...), wheel align, solid subframe and diff mounts, and proper tune.
But it goes, skids and sounds angry, haha.
SO in other words look out the streets of Hobart :)
Picked up my new 040 from SPG last week so all that leaves is tuning of the blue bucket :)
Well, rear subframe bushes let go, ordered some new ones but got sent wrong ones.
Made some phonecalls and was told Nolathane were outta stock till mid July. Now I am told its mid August...
So I decided to pull the front end apart and replace the LHF Inner Driveshaft boot. Easy enough job, except nobody has a boot that fits... Spose my local Nissan dealer will tell me they are about $90 each and 4 weeks outta Japan next for a genuine one.
So the GTR is sitten on stands with bits missing everywhere and the Baskerville Hillclimb is on in three weeks. This will be pushin it to get everything here and done by then.
Dude that is F'n harsh!
What about the RB25 thats for sale??
Didn't want to go RB25 as none of my parts (cams, gears, injectors etc) would fit, would need a new ecu and turbo not ideal either.
I know the feeling, i order some gear for the FC from Rare Spares and they sent me the wrong items, when i rang to let them know they informed me that they didn't have what i needed instock and that it would be 12 weeks before they would have what i needed :rolleyes:
well, my mate fixed my powerfc so kermit is back in action! hoping to enter basky hillclimb too which should be fun :)
Glad to hear its all sorted, lets hope nothing else happens now :bunny:
Well thankfully I managed to fit the aftermarket boot to the driveshaft. Looks like it will work for now.
So as long as I can either get the bushes from Nolathane or temp up some "pineapples" I should be good for the Basky Hillclimb yet again.
The race is on, i have to remove old engine and put on stand to remove cams, injectors, gears and covers. Tidy up engine bay whilst its out and then when new engine arrives fit cams, injectors, gears and covers before dropping that back in.
Have to fit 040, new seat/harness and harness tabs and then tune it so i can make the hill climb :(
Racin before the event and all... thats competitive.
Well I just selected another gear, bush kit arrived and was the correct one this time.
Just arranged shed space, as mine is full at the moment, for this Saturday to fit em all up.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
