i got that HD go pro too, good quality camera, had misplaced the case and mounts for it when i lent it to a mate last few track days though haha but have it all back now. got external mounts and rollcage mounts. i usually record it in 720p @ 60frames, best quality/ smoothness setting around for that cam.
Have uploaded several vids to youtube with some recordings of it.
took my car to a club day at symmons yesterday
not sure if these will embed. just some average quality from my mates steady hand haha
if you havent seen my build thread take a look.
http://www.skylinesaustralia.com/forums/topic/308918-damos-r32-gts-r-on-going-project-fun-car-history-and-use-full-info/page__st__220
:closedeyes: OK!!
so i was going about it the wrong way!! so i went in and had a big chat this morning ..
now we are going too
install turbo kit ..
do the timeing belt as its never been done ..
engine flush and some new fluids .
have a look at the fuel pump the guy i brought it off said it was a gtr 1 so if its true that will be untuched
ill have enuf money left over for the vipec ecu install and tune .
depending on $ after that injectours !
just a quick thanx to all the reason i come on here is to get some kind of guide on the best parts to redo..
engine will now remain un opend..untill maybe oneday it fails ! !
Edited by Addicted2BoostR34
why the vipec?
a lot of $$$ if its only going to be mildly modded
nistune will support new afm, injectors, raised rev limit, remove speed cut and i think you can keep tcs
also looks like knock maps will be tunable soon (pfc doesn't have this feature apparently)
about $1k tuned and fitted!
why the vipec?
a lot of $$ if its only going to be mildly modded
It's true, NisTune is pretty win.
But any ECU is only as good as it's tuner, so what ever your tuner is most comfortable with really.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
