sooo ! got my car back ! love it turbo sounds insane spooling up as well sending my ecu off next week to nistune for the tickel and lick lol then ill have to look into AFM Hmm after some reading a z32 could be my next upgrade .
all thats new for me is my dent has been fixed just waiting to paint it nowthumbsup.gif & i also worked out i still have the mines ecu, witch would explain why i don't have the speed limiter & the rev limit has been raised thumbsup.gif
another one? :( i think a mate may have one if you haven't got one already,
as for my car i was going to see if the GTR bar that toffy lent me would fit but i would have had to un mount my cooler & it was dark so ill do it another day, also found a split catch can hose pinch.gif all fixed now thothumbsup.gif
any other 33 owners have surge issues when around quarter of a tank? thinking i may need a new pump or maybe a surge tank
Edited by Autumn33
R33s are usually pretty good for fuel surge because of the nice shape of the tank. I've still just got the stock fuel setup with a walbro pump, loves to drift and I spin out more often than not, haven't had any problems with surge.
Just check that who ever changed it didn't fit it back in the tank wrong , when i first got my white 33 (or my ex's now) it had been changed and they put the fuel pump where the level indicator thingy is supposed to go , if i cornered hard right it would run out of fuel under 1/3 of a tank pinch.gif . And check it's in its mount properly too!
Well today I got stuck into hacking up my front bar, and picked up a huge ass sheet of 2mm aluminium to make my splitter up. ordered some nice adjustable turnbuckles out of the states. gonna have to wait a week or two for those babies to arrive but that gives me time to repair the rest of the bar and start prepping for primer.
also have some bilsteins to replace my knarley old Tein HR's. so the Ol' dusty datsun is seeing a bit fo love atm.
look forward to seeing this splitter :yes:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
