sooo ! got my car back ! love it turbo sounds insane spooling up as well sending my ecu off next week to nistune for the tickel and lick lol then ill have to look into AFM Hmm after some reading a z32 could be my next upgrade .
all thats new for me is my dent has been fixed just waiting to paint it nowthumbsup.gif & i also worked out i still have the mines ecu, witch would explain why i don't have the speed limiter & the rev limit has been raised thumbsup.gif
another one? :( i think a mate may have one if you haven't got one already,
as for my car i was going to see if the GTR bar that toffy lent me would fit but i would have had to un mount my cooler & it was dark so ill do it another day, also found a split catch can hose pinch.gif all fixed now thothumbsup.gif
any other 33 owners have surge issues when around quarter of a tank? thinking i may need a new pump or maybe a surge tank
Edited by Autumn33
R33s are usually pretty good for fuel surge because of the nice shape of the tank. I've still just got the stock fuel setup with a walbro pump, loves to drift and I spin out more often than not, haven't had any problems with surge.
Just check that who ever changed it didn't fit it back in the tank wrong , when i first got my white 33 (or my ex's now) it had been changed and they put the fuel pump where the level indicator thingy is supposed to go , if i cornered hard right it would run out of fuel under 1/3 of a tank pinch.gif . And check it's in its mount properly too!
Well today I got stuck into hacking up my front bar, and picked up a huge ass sheet of 2mm aluminium to make my splitter up. ordered some nice adjustable turnbuckles out of the states. gonna have to wait a week or two for those babies to arrive but that gives me time to repair the rest of the bar and start prepping for primer.
also have some bilsteins to replace my knarley old Tein HR's. so the Ol' dusty datsun is seeing a bit fo love atm.
look forward to seeing this splitter :yes:
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
