my remsa pads just arrived from gslrallysport :)
i bought fronts for the stagea (r34 4 pots) and fronts for the corolla (probably overkill really)
keen to see how they are compared to the current pads, just wondering if i should machine the rotors first
QFM pads are best bang for buck pads out bar none. Aus made, and they rock. I run A1RM pads on my car and they are bloody awesome.
and yes, machine away. a fluid flush is always a healthy option too.
these pads sit between the hpx and ar1m aparently, gsl rallysport are phasing out the hpx's apparently because these are supposed to be better for only $10 more ($89/set)
so tempted to put them in tmrw, but i don't want to bed them in twice and it could be a while before i have a spare car again (corolla is up in the air with about half way through a clutch change atm)
little update got my ecu back hello nistune :)
also .. im lookn at getting my frount bar painted and fitted befor i do anything more i F!@#en hate driveing around with it off looks bogan :domokun:
so whats a good place around L'ton to get it painted and fitted @ a good quality for $$$ cheers i looked at micra ?? i just dont know at all pinch.gif
Finally finished spark plugs! Old plugs were gapped to like 1.4mm! Then took it for a Razzle dazzle on some gravel around sandfly. Seems to have a little more poke off the bottom now which is nice. Missing seems to have stopped too :) true test will be tomorrow though
finns body works near the old coats paintens building. they paint all my mates cars and never a complaint.
so nistune arent super fast with there service then?
pic of 34 from back when i was putting it back together :thumbsup:
Looks good Toff...
Sooooo envious- hoist!!! I just spent all afternoon on my back pulling and reinstalling a gearbox in the gts-t. What a pain in the ... well everything!
cheers na nistune where good i wasnt fussed how long it took so i posted it to confidyne and they sent it away with there one i havent been home to check my mail >.<
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
