my remsa pads just arrived from gslrallysport :)
i bought fronts for the stagea (r34 4 pots) and fronts for the corolla (probably overkill really)
keen to see how they are compared to the current pads, just wondering if i should machine the rotors first
QFM pads are best bang for buck pads out bar none. Aus made, and they rock. I run A1RM pads on my car and they are bloody awesome.
and yes, machine away. a fluid flush is always a healthy option too.
these pads sit between the hpx and ar1m aparently, gsl rallysport are phasing out the hpx's apparently because these are supposed to be better for only $10 more ($89/set)
so tempted to put them in tmrw, but i don't want to bed them in twice and it could be a while before i have a spare car again (corolla is up in the air with about half way through a clutch change atm)
little update got my ecu back hello nistune :)
also .. im lookn at getting my frount bar painted and fitted befor i do anything more i F!@#en hate driveing around with it off looks bogan :domokun:
so whats a good place around L'ton to get it painted and fitted @ a good quality for $$$ cheers i looked at micra ?? i just dont know at all pinch.gif
Finally finished spark plugs! Old plugs were gapped to like 1.4mm! Then took it for a Razzle dazzle on some gravel around sandfly. Seems to have a little more poke off the bottom now which is nice. Missing seems to have stopped too :) true test will be tomorrow though
finns body works near the old coats paintens building. they paint all my mates cars and never a complaint.
so nistune arent super fast with there service then?
pic of 34 from back when i was putting it back together :thumbsup:
Looks good Toff...
Sooooo envious- hoist!!! I just spent all afternoon on my back pulling and reinstalling a gearbox in the gts-t. What a pain in the ... well everything!
cheers na nistune where good i wasnt fussed how long it took so i posted it to confidyne and they sent it away with there one i havent been home to check my mail >.<
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
