installing my new fuel pump from tuff car parts today aeromotive stealth 340 :D
so turns out the "GTR" fuel pump is missing? and in it place was a stock old std pump with no filter sock -.-! so glad i got a new one that could have killed the engine ? ( no filter = sucking shit from tank= fuel block= death?)
the block who had it befor me got a garage in L'ton to install a new gtr pump because they said his old one was stuffed turns out they ripped him right off :domokun:
Hi guys,<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">Had this R32 for a couple of weeks now and she wasnt running the best. And as I plan on goin to Melb for chrissy holidays I decided to take her in to get tuned and dyno'd.<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">So with the following mods (next to nothing... lol) this is what she ran<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">
  • 3" Turbo back JJR exhaust
  • R33 turbo
  • Turbosmart Manual boost controller (Bleed type)
  • Turbosmart Boost gauge
  • A'pexi SAFC II
  • HKS turbo timer
  • HKS style pod filter
  • Stock fuel pump
  • Stock Injectors
  • Stock coils
  • Stock cam
<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">This will be classed as the "Before" dyno, as i plan on goin back to JEM after chrissy lookin for 250+ rwkw... :)<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0769-1-1.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0764-1.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0815.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0914.jpg
Hi guys,
So with the following mods (next to nothing... lol) this is what she ran...
  • R33 turbo
  • A'pexi SAFC II
  • HKS turbo timer
  • Stock fuel pump
  • Stock Injectors
  • Stock coils
  • Stock cam
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
