clean up the cut out part and practice on it?
they arent overly hard to set up, might as well practice on it, its only a 31, =P
yeah i've done a tiny bit of arc welding and i've got a tonne of rods (but no welder)
i don't think i could arc the 31 tho because the pannels must only be 1-1.5mm thick (rods are 2.5 so way too beefy)
anyone selling a cheap mig welder?
i belive you can hire MIGs at a pretty good rate.
like everything a cheap welder will give cheap results. a half decent one will do a good job with a bad operator.
dont get a gas less mig. may as well stick weld it.
Do like, the GT-C's will look mint ( if your still putting them on it )
Nothing really new on my car put on a new intake pipe ( stock one with a section cut out & filled with a piece of pipe ) as i found my old one had a rather large split on the underside
new pod ( +25kw :laugh:)
oil change & filter
just waiting till next week to register it and finish my pipes so i can have it all ready for time attack ( being a poser on the hill :sleep: )
Edited by Autumn33
just a quick question, would having the wires to my tps cut have anything to do with why my car wont idle till warm? drives fine while cold just wont idle, only way i can get it to idle is unplug the afm till its warm. (just realised the plug has been cut)
Or could it be my acc valve?
Has all the tubes from the tb missing also but ive read that wont affect it.
Will be cleaning the acc tomorrow to see if it helps.
Dose your idle controll valve have a hose going into the cooler pipe work pre-throttle body?
The TPS has 2 sets of wires, one is the throttle signal, and the other is the idle switch. Your idle switch is cut, so your car will idle like shit. Also is the TPS isn't adjusted properly, the idle switch will never activate.
Edited by sav man
For some reason i have a breather on the aac valve. Has a T piece with a breather and a hose that leads to a black plastic box :wacko:
Edit: managed to get my phone down there to take a pic, not the best but it shows what i mean about the breather & the black thing.
Edited by Autumn33
yep pretty simple. where that air filter is that line needs to be plumbed onto the turbo side of the throttle.
that would be sucking un metered air during cold start and idle. its a wonder it doesnt stall when you stop at lights.
that black box thing as you described is a heat activated air bypass valve. or cold start valve. its fully open when the car is cold and as the block warms up it closes off. it also has ignition power to it to help it close off. this is why under cold start imports rev heigh for the first few minutes then slowly go back to normal.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
