Nah just saw it on there. Was considering putting a bid on it but decided I probably have too many cars as it is. Looked like a pretty easy repair
Yep , i wasn't going to bid on it either , but i was on there watching something else :blush: , if the damage is worse than it looks in the pics i'll probably just wreck it
Buy the rota p45 from Rota aus on facebook, $1099 including delivery for 18's
cheers for the heads up, just checked them out wanted to go 18x9.5 +12 & 18x12 +20
but i dont want to hack my front guards or go wide rear, so thinking i may have to go 9.5 +32 & 10 + 35 :glare:
as im thinking +12 all round would still need guard work even though mine are allready rolled
interesting, mines quite abit lower then yours though.
i failed before the fronts would be +25 not +32
they have.
18x9.5 +12, +25
18x10 +12, +35
18x12 +0 +20
so thinking ill need 9.5 +25 fronts & 10 +35 rears
this 33 has 9.5+12 all round and looks mint! but no specs on camber ect
Edited by Autumn33
so after working it out on the offset calulator & then getting the trusty ruler out, im thinking i should be able to just get away with the +12's with some more rolling/lipping & stretch
Edited by Autumn33
Not too much to update. Last monday I put a new water pump, idler bearing/new Bolt and tensioner bearing on the old girl along with a new gates timing belt.
Yesterday arvo I made up my rear wing/boot bracing. very light and holds my weight very easily. I have made up a ally plate that fits nice in the passengers side of the boot to mount the surge tank and pumps/pump mounts to so it goes in and out as one piece. will plaster the rising sun over the tank and plate to mtach the engine =)
I'm at a bit of a cross roads with weight atm. I've sorta came a bit of the way and not quite sure where to draw the line. The head unit and 2 door speakers are in question, door intrusion bars along with door glass, might trade it for lexan... I would love to gut the doors and power windows and just have lexan in bare doors but I also want to keep from the B pillars forward in tact. I really want a carbon boot lid and then mount it on pins/latches and do away with the big factory hinges but that will have to wait as the money needs to go on more important stuff ATM
Got a ally rear diffuser/air guide planned for the rear. will get that underway in the next few weeks. more to aid airflow than provide any sort of extra dwonforce as ATM air can get trapped in the rear bar/boot floor area.
cheers
OMG, so much porn in those pics. Heaps jelly of your aero. If I had it though I'd just go backwards over a curb with it :P
Swapping Glass for Lexan I think is time to draw the line, skyline glass isn't that heavy anyway! You're better off spending the $$ on petrol and Tyres :)
its hard Nowelly. I need a new rear screen anyways. And I have spoken to Burgz about getting 2 orders shipped together. should be able to get a rear screen and door screens (and quaters but prob wont use them) in lexan here for 600ish. I was quoted over 300 for an aftermarket rear glass screen.... the door glass is actually kinda heavy. I know the rear isnt.
A nice light motorsport battery is def on the cards later in the year after the important stuff is out of the way.
haha yeah really its not huge coin. not when your already up for a rear screen anyway. its usually about 700 but if we can get two kits at the same time should save a bit on postage, shipping 2 kits compared to one shouldnt make shit all difference so should come in around the 600- maybe 650 tops. I prob wouldnt of bothered if I didnt need any but since I need the rear, kinda a 'may aswell while i'm there' thing lol
looking good Jack
cheers
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
