Had the R31 stolen from outside of our house 2 nights ago (tuesday night)
Very stressful, especially with an exam the next day
Police rocked up and took down some info (luckily a mate in town spotted it and we passed that onto the police, not that they did much about it)
Got a call Wednesday morning and it had been found in Hobart! and seems to be in good condition
Now insurance are going to look at it and make sure everything is ok
Really not what i need during exam period, also heading to Qld on sunday so i have no idea what im going to do about getting the car back.
Pretty happy the didn't torch it tho
Haha, how do you manage to store all these cars?!
Also, we recently bought your old black R32 shell off Daniel, and I was wondering if you would happen to have the import papers by any chance?
PM me if you want, I tried to PM you but couldn't for some reason :)
Haha , few here , few there , no joke i have lost cars before lol (and found them again ) . That black shell was registered previously in tas so it doesn't need import papers , just a sales receipt and pit pass :) , now i think of it though , i vaguely remember the vin wasn't stamped on the strut tower , you would need to get that stamped , you can check the vin with service tas in memory by ringing them , it will start with 6u9000 then the factory vin , the ais station that originally passed it needs a smack on the fingers for not doing it
Ok awesome, yeah it does need the VIN stamping on the strut tower, I remember Daniel mentioned it when we bought it off him. Not 100% sure if we're going to register it yet but it would be nice to have the option to in the future.
I see Peter tagged you in the photo on Facebook so I assume you know it still has the yellow guards :) I actually saw your yellow 4 door today with the black guards on it so if you want to swap that would work out well, although I will say the paint on the left hand side is a bit poor, not sure if it was like that when you had them or not.
Ahh yep , it's definitely a complied shell . Yes i would like to swap front guards (get the missuz off my back about painting it lol) , the black ones on the yellow car are average too , the right one has a couple dings and the left one has a hole cut out for an indicator , my ph is 0419552441 if your interested in swapping :)
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
