Lol. If I was still on them I would have been upside down through that corner. I personally use the 595 over the evo any day but I have found they have a limit. I've changed to kuhmo at this stage. 1 2 in the champion ship they must be ok. They have so far been light years ahead but they are way expensive
I have several aspects to revamp on the. Car but can't seem to get into it. Any one got a way to get yourself motivated?
This weather doesn't help much. If you have a goal it helps, as in set a date. Although we figured out you have to be realistic haha.
Spent a bit of time today doing surgery on our car, nothing major just cutting out battery tray which is diseased with rust!
Not sure how much I need to cut out though, if you look at pic below you can see a few areas I have cleaned up with wire wheel that are pitted from rust but not rusted through, do these areas need to go as well or is it ok to just treat and paint?
Just coating that should be fine
Yeah as jangles said just treat and paint. As long as the Strength of the metal is still there then there's no need to remove it. By cleaning it up like you have and treating it with a metal conditioner/rust converter it will never come back as long as you coat it properly.
So thinking of installing my new BC coilovers myself soon when i get the time, any tips to make it go smoothly, im pretty sure i can do the fronts no problems, just the back im a bit unsure of, ive seen a vid on youtube where he just removes the rear seat, but ive read somewhere that you need to remove the parcel shelf?
also other than height is there anything else i need to adjust before/during install? im prob gonna put the damper on soft as its for the street, but anything else you guys could recommend?
Finally found some motivation. Got a stack of work done to the car today. Repainted one and touthed up the other rims that got badly gravel rashed at symmons. Oil change and sump guard fitted. I've also been revamping the back end and removing weight where I can. Found the toe rod ball joint loose and replaced it with the only spare I have.. Brought a spot drill bit and been in studying panels where I can. Also got some alloy to start making a rear diffuser. On track for round 3. Also hoping to get to the legerwood lane hill climb.
Not too sure you can mate. If your talking about the little spring that sits below the main spring it's just there to locate the top spring and stop it from moving off the seat when under full extension.
ok well from what i figured about he coilovers, the very bottom collar is for lowering/raising the car, and the top one adjusts the preload, the one just below it, makes sure it doesnt move, and from vids and reading new springs can 'settle' so one vid said to tighten the preload by about 5mm to account for that, and i have been told that you just adjust it after bit of driving... just wanted to see if what others have done, so ill prob just install them and check them after a few days...
ok cheers thanks for that,
last thing in this pick my coilovers came with this thing just above the 'c' collar that adjust height, never seen it on a coilover before,
is it ok just to take it off?
it would be to bolt the abs sensor cable to for abs equipped cars
ok cheers, thought that could be the case, as i had a quick look under the car and the stock shocks have something sticking out, i guess its no use to me then
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
