  • Replies 181
Posted Images
Jeez! everyone is suddenly jumping onto the bandwagon ! LoL Anyway, HID's will fit anycar! (with a standard lighting system that is, EG: H1,H3,H4,H7..etc). Sorry for the delay Ban, will get it done today! CheerS! And remember pple! 15A fuses! If not u'll keep blowin up the damn fuses.LoL.
yes u can ..
i'm living in waterford.. after i get them i'll post here and u can come n collect em
... 6kk is the brigtest??or 5000???
4700~5300 range is the brightests rated at 3200lm. 6000k is 2800. But i personally prefer the white light with the bluish tinge. but if u think about it, 400lm at such a high level is not that big a deal. if u compare it to the standard 1000lm. It's like when u change from a 15" to a 17" monitor, u see the big diff, but from a 17" to a 19" u don't really see it, untill u jum from a 17" to a 21" then it makes a big difference. =)
Yeahhh, was thinkin we could arrange a day when the stuff arrives, then we could all gather on a sunday afternoon and get it installed together. Prolly someone could get the 15A fuses for everyone at a shot too. ;) Then, when have a drink together, and when night comes, everyone can show off their new set of HIDs ! :D
that'll be really cool ..mate ..
Yeahhh, was thinkin we could arrange a day when the stuff arrives, then we could all gather on a sunday afternoon and get it installed together. Prolly someone could get the 15A fuses for everyone at a shot too. :D Then, when have a drink together, and when night comes, everyone can show off their new set of HIDs ! :D
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
