My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :P
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
TYRES: 255/40/17 A048'S
NITRO: NO
video link - right click save as
Edited by Angus Smart
My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :closedeyes:
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
NITRO: NO
woah!! for a first run, thats awesome!!!!
R31 silhoutte
60ft:1.68
10.21 at 140.89mph
pump fuel, full exhaust, 25psi, footbrake(transbrake not working), et street bias plys
Rb30 SOHC, 850hp gt4294, powerglide, 3500rpm stall, 3.45 diff gears.
a chick in the 10s!!! AWESOME!! :) nice work :D
Thankyou! i think i might get the fcon tuned, my afr's lifted somewhere from below 9 to somewhere a bit leaner
get a tripod and an in car camera and do it again in a few weeks. it should be another fun night for the few minutes of running! and hours of waiting :(
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :thumbsup:
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :)
Hey just using yokohama a048's i'll probably head out in a few weeks! you had much luck selling yours yet?
howd you get down to 10.7? i was aiming for something like that :)
howd you get down to 10.7? i was aiming for something like that :rofl:
Just drive the ass off it Blue Brother!!! Federal tyres at 20psi. Plus it was only 10.9 :w00t: . Plenty of wheelspin though. No real luck selling it yet but thats fine cos I love her! :blink:
Car: R33 GTST
Turbo: Slide high-flow
Tyres: Federal SS595 255/45/17 @ 18psi
Date: 03-05-07
Time: 11:05pm
Output in rwkw: 215 according to the Allstar dyno......
Track: Willowbank
Air Temp: 16 degrees
Track Temp: 25 degrees
Humidity: 1015mB
Reaction time: .597
60ft: 1.841
330ft: 5.36
660ft: 8.22
1000ft: 10.68
ET: 12.70
MPH: 112.3
Car: R32 GTST
Turbo: 2535
Tyres: M/T 255
Date: 02-05-07
Time: 09:58pm
Output in rwkw: 235
Track: WSID
Reaction time: .446
60ft: 1.868
330ft: 5.274
660ft: 8.122
ET: 12.55
MPH: 107.8
First time @ any leagal drags.. loved it !
Edited by jnr32r
Car: R33 GTST
Date: 16-05-07
Time: 5:39pm
Track: Willowbank
Air Temp: 21 degrees
Track Temp: 29 degrees
Humidity: 1018mB
Reaction time: .782
60ft: 1.73
ET: 12.58
MPH: 111.3
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
