My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :P
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
TYRES: 255/40/17 A048'S
NITRO: NO
video link - right click save as
Edited by Angus Smart
My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :closedeyes:
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
NITRO: NO
woah!! for a first run, thats awesome!!!!
R31 silhoutte
60ft:1.68
10.21 at 140.89mph
pump fuel, full exhaust, 25psi, footbrake(transbrake not working), et street bias plys
Rb30 SOHC, 850hp gt4294, powerglide, 3500rpm stall, 3.45 diff gears.
a chick in the 10s!!! AWESOME!! :) nice work :D
Thankyou! i think i might get the fcon tuned, my afr's lifted somewhere from below 9 to somewhere a bit leaner
get a tripod and an in car camera and do it again in a few weeks. it should be another fun night for the few minutes of running! and hours of waiting :(
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :thumbsup:
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :)
Hey just using yokohama a048's i'll probably head out in a few weeks! you had much luck selling yours yet?
howd you get down to 10.7? i was aiming for something like that :)
howd you get down to 10.7? i was aiming for something like that :rofl:
Just drive the ass off it Blue Brother!!! Federal tyres at 20psi. Plus it was only 10.9 :w00t: . Plenty of wheelspin though. No real luck selling it yet but thats fine cos I love her! :blink:
Car: R33 GTST
Turbo: Slide high-flow
Tyres: Federal SS595 255/45/17 @ 18psi
Date: 03-05-07
Time: 11:05pm
Output in rwkw: 215 according to the Allstar dyno......
Track: Willowbank
Air Temp: 16 degrees
Track Temp: 25 degrees
Humidity: 1015mB
Reaction time: .597
60ft: 1.841
330ft: 5.36
660ft: 8.22
1000ft: 10.68
ET: 12.70
MPH: 112.3
Car: R32 GTST
Turbo: 2535
Tyres: M/T 255
Date: 02-05-07
Time: 09:58pm
Output in rwkw: 235
Track: WSID
Reaction time: .446
60ft: 1.868
330ft: 5.274
660ft: 8.122
ET: 12.55
MPH: 107.8
First time @ any leagal drags.. loved it !
Edited by jnr32r
Car: R33 GTST
Date: 16-05-07
Time: 5:39pm
Track: Willowbank
Air Temp: 21 degrees
Track Temp: 29 degrees
Humidity: 1018mB
Reaction time: .782
60ft: 1.73
ET: 12.58
MPH: 111.3
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
