How many Buckets?
33 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
what the hell? 8-10... crazy...
i just use like 2 buckets... spray the car down at carwash, fill up bucket with water and add cleanser... wipe down car with sponge (using that cleanser water)... spray with water again... chamois it... add polish/wax...?
Edited by Menthu_Rae
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1658895
In light of the "How often do you clean your car" thread, I thought it would be interesting to see how many buckets the average budding car enthusist uses to clean their pride and joy?
Too many...
I'm sure I would use a heap less water if I used the hose.
On a serious note, I probably use around 6-8 buckets of water (big 20L bucket as well) when I wash the car. I've kinda given up using the bucket though, so I usually end up getting the car washed at a cash wash while I enjoy my caffine hit on a Saturday morning - which I plan on doing shortly :P
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1659076
i use 0 buckets of water!
cause i use Dri-Wash 'n' Guard
its the BEST you people should try it
its a waterless carwash
just buff on and polish off
and i am yet to find a better one (it removes small scratches and everything)
only time i use water is if car is REAL dirty (which is never!! of course)
i only used water the first time cause if u use dri-wash, then water, then dri-wash again it locks in the wet look and is awesome
Should try it nothing better
RellikZephyr
Edited by RellikZephyr
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1659096
How many buckets would you fill with the water you used to hose the car down twice?
Now how many buckets would you need if you had to fill up buckets of water first, and then throw the buckets of water over the car to wet it, and then rinse it?
I have one of those hose "guns" that I "shoot" when I need water.
It takes about 30 seconds to fill up my bucket with water. It takes about 45 seconds of spraying to intially rinse down the car, and then perhaps a minute to rinse off the suds after washing. Say about 2 minutes of hose use all up. So that's about 4 buckets?
I can tell you WITHOUT A DOUBT that it would take me about 6-8 buckets of water just to do the final rinsing off after washing to get the suds off the car. Pouring a bucket of water to wash things is sooooo inefficient.
So I think it's quite reasonable to suggest:
I would take 12-14 buckets of water to wash my car with a bucket, and only 4 buckets worth with a hose.
Congratulations NSW Government on another well thought out water restriction! :)
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660074
what a waste of effort, i dont know anyone who actually uses buckets to wash their cars, just trigger hoses, same shit, o and make sure you wash the concrete driveway down to when your washing your car, so you dont have to waaste your time with the broome..
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660078
Congratulations NSW Government on another well thought out water restriction!  :rolleyes:
Gotta agree with that. I use the hose most of the time as I'm sure I use much less water than if I fked around filling buckets and tipping them on my car.
However, I usually use the car wash to avoid the scrutiny of my neighbours, even though I'm sure this wastes more water than me with hose or buckets.
Edited by shyster
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660227
Congratulations NSW Government on another well thought out water restriction!  :D
My answer exactly. Ive had neighbours complain and i just ask them to watch the difference between using a bucket and a trigger hose.
Everytime they see my side. The NSW gov has just inforced the bucket rule because people can not be bothered to use one so wash their car less which uses less water.
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1666745
the real question should be how many buckets does it take to drench the people who rat me out to the water restriction nazis...
answer, 1 per person.
I hear that. and they are usually the ones that are hosing down their driveways anyway when they not supose too ... divkheads <_<
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1672608
well i now have 2 rainwater tanks in my house. one is 5000 litres one is 3000 litres..hmm maybe it's 000s can't remember. either way i now have shit loads of clean free water to do with as i please. we have connected spray irigation to both front and back gardens and retracting lawn sprayers too. each tanks has it's own high pressure pump so you can hook up a hose and enjoy even better pressure than what you get from the mains. plus the irigtation system is computer controlled and has moisture sensors in the ground. it certainly is a kick arse system and means we can do what we want with the water. so if you drive past my house and see our irigation running don't whinge to sydney water as it's our water to do with as we please :)
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1673623
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
