was just seeing all the threads on different gloveboxes - i just assumed they were all the same... and mine seems different again to all the other descriptions - mine opens from BOTH sides and is full depth for CDs etc... most other people whos open both sides seem to have posted that they are very shallow... weird so many different ones!
And yeah - factory Xenons with height adjustment for the high beam, controlled by a thumb-wheel on the dash to raise or lower the pitch down the road.
Edited by Brazen
I would have thought this test (fanging on a dirt road) ineffective because of awd?
hmm, you should still be able to tell - if you can't what is the point of having one! :P I haven't been on a dirt rd in my stagea yet (it does have the lsd as it is a four S), so can't comment from experience..
Ian
Wow that is cool!!!
My centre console storage space is NO WHERE NEAR that deep, and mine only opens from the front, it is hinged at the back, so it opens up like my old r33 did.
I never knew you could get it to open up from either side, cool!
I'll take some pics of mine on the weekend :P
Thanks Nick!!
Sorry pics took so long, but as promised here it is :w00t:
As you can see it is only like 2 inches deep, but when you reomve it to see what is underneath, it has this MASSIVE airbag thingy box directly underneath it, dunno wether that is where is is on stock cars though....?
It's a big silver box with cuation airbag stickers all over it and heaps of wires running from it towards the front of the car, looks like it belongs there as all the mounts for it are there and it actually sits raised about 1cm off the floor pan.
I'll take some pics when I can, dont hold your breath though :(
Owned :(
Airbag thingy? Is it an airbag or what? If it is, how the hell did they do that converting to manual
It is the g-force switch(if you call it that?) that sets the air bags off in your dashboard and steering wheel
Basically when you have a accident, the switch makes contact inside from the force of the impact and off go the airbags
I'll take some pics when I can, dont hold your breath though :P
It's most likely the computer with the g-sensors, as Darrin has mentioned. Don't forget, also, that GT-Rs (and probably GTS4s) had the g-sensors under the centre glovebox, behind the handbrake, and this was used as part of the triggering functions of the ATESSA computers. Seeing as most of us have RS-Fours, then they should all have them there, whether stock or converted to manual like mine and Ska's. I haven't bothered (or had the need) to take that part of the centre console off, so I can only assume they'd be in the same spot.
Who knows, maybe the same g-sensors were used for the airbags and the ATESSA!?!?
  • 2 months later...
  • 1 month later...
hey, i tried that, and i got pinged with a $99 parking in loading zone fine, they didn't believe i was on business, which i was... lowsy parking guys
A bit OT, but since when in NSW does it matter if your private rego'd or business.
It is my understanding that any wagon, ute, van or larger LR/MR/HR vehicle can legally park in a loading zone.
Alright, ignore what I said inpost #54, the airbag computer and ATTESSA sensor are separate items...
Airbag ECU:
Airbag ECU (bottom of shot) and ATTESSA sensor (top of shot) with whole console removed:
ATTESSA sensor just behind the gear shifter:
  • 1 month later...
I would like to add a link to this thread in the "Stagea Diy's, How To's, & Fyi's" thread here:
http://www.skylinesaustralia.com/forums/in...howtopic=102808
And then unsticky this thread, any objections?
I think this is one thread we should leave exactly as it is now, we still have a lot of people visiting this part of the forums asking questions, and having it kinda hidden away makes it harder for those who are new to Stageas and are thinking of making a purchase or doing extra research.
I think the DIY section is better for us who already own them, and know to use it as a reference point when looking for instructions, etc. when we're doing repairs and/or upgrades. For any of those types of threads, then they could be put in the one DIY section...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
