as per PM reply brendan, you'll have alot of trouble making them fit (particularly since i get the feeling you want to put them on the front - talking about clearing big brakes)
if you are set on te37's get some 18x9.5+12's all round but be prepared to pay a mint as your pm suggests you want brand new ones
thanks for that info mate
probably go for 18x8.5" +35 as per attached
will put big brake kit on track car project with bolton spacers & stag rear calipers
and throw the r32 gtr calipers allround (with new track pads) onto the stagea
wheel.doc
Hi guys,
I'm New on the Board and i am really happy for so much stagea Fans!
I'm from Germany and i have an 260RS. In next time i will tell more about from my Person and the stagea!
I have two fast questions about the rims at the stagea. Is it possible to have an 8.5x18 et36 and 10x18 et37 rims without Problems? Know how Annone? Second, i have four 245/40 tires for this rims, is it ok to drive that on a 10J?? I really happy for your answers and tips.
Greefs from berlin
Edited by 260RS@R33Typ
Hi guys,
Greefs from berlin
Hi and welcome!
You HAVE to keep the same rolling diameters between the front and rear. If you run the same tyres on different sized rims, it will not work. The rolling diameters will be different because of the stretching of the rear tyres to fit over the 10" rims.
You should try and find a set of wheels and tyres that are the same size and width front and rear, or you will have BIG and expensive problems with the transfer box after you drive it for a while.
  • 5 weeks later...
Helo Guys,
just to confirm this.
18x9 +20 5/114.3 fitted with 245/40R18 will fit onto the 260rs? Cos i read somewhere in this thread that i wll need spacers and longer wheel nut for the rear rims.
thanks peps.
I'm not sure if they will fit without hitting on the strut, if they do fit then they will be sunken inside the guards heaps.
Also, for an RS4 due to the ATTESSA system you would be better off running the same width front and back, unless you work out the tyre sizes so you can maintain the same front and back rolling diameter.
G'day All,
Nice thread, heaps of info on offset for manuals, just a little about offset for autos though?
My Partner is in the process of buying herself a completely stock std S2 RSFourV Tiptronic Stag.
Stag to be lowered on Tein Wagon S-Tech Coils - Then She wants some nice rims!
Short of me trying my R33 GTR and AU Falcoon rims (when we get it home), can some smart person suggest the best offset for 18 x 8.5-9 rims all round - considering from what I have read the auto has a wider rear end in it compared to manual.
Advanced thanks for your time and info,
Cheers Mike.
Hi is anyone running 19x9.5 +12 on a rs four s without rolling the guards or is this to aggressive! Sorry if this has been covered! Thanks in advance for any help
That is exactly what I run. No guard rolling. 245/35/19 tyres with acceptable rear camber. 330mm ride height
Thanks your is exactly how id like mine to sit! Is there any more room under the front guards with the 34 front compared to standard??
rims :- RAYS LM GT4
size :- 19 x 9.5 +30 offset
tyres :- Dunlop Maxx SP
size :- 19x35x245
fits a lowered m35 without rolling the gaurds thus far.
Thats mad. Look at those things! More photos please!!! I'm glad you didn't give up or listen to the "mechanics..."
:P
edit- found pics! NICE :yes:
Edited by PN-Mad
ok, ive tried figuring this out for myself here...
would 19x9.5+15 fit a stagea?
or +22? (theres a sick set of Rays GT-C's on a website that i've got my eye on)
and whats the deal with the 260RS? rear offset is different to the front yes?
if those offsets are wrong could someone tell me what offset i'd need to run 19x9.5's (or 10's if possible...)
thanks Brendan.
thanks Brendan.
What model C34 do you have?
Auto?
manual?
260Rs with Brembo's?
That will determine what fits
When looking at Rays wheels against width and offset there is a couple of things to consider
Depending what on the offset on a certain size will deteremine what the caliper clearance is as referred to by Rays as disk type A, B or C
If you check out the Rays site, find the wheel you want, pick a size and compare it to the charts. If you need a "A" disk clearance, the offsets are different when compered to a B or C disk
Example
I run Rays's GT-C's Face 2 in a 19x9.5 +12, manual rear end.
Check the charts and you will see they are a "B" disk with 86mm outer rim (dish) Only just clear (1-2mm) r34 GTT 310mm dia brakes.
If I went to 19x9.5 +11, only 1mm different in offset, but they are a A disk (fit over brembo's) but with a 73mm out rim (so less dish)
Hope this helps.
http://www.rays-msc.com/wheels/index.cgi?d=19
http://www.rayswheels.co.jp/2009/products/...mp;for=domestic
Edited by darrinspencer
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
