Rota DPT's look nice!, what size tyre?
I was thinking about rota boosts in 18x9 +27, will i have any fitment issues without coilovers? S.2 automatic
Should be be pretty flush with the guards as its within 3mm of a R34 GTR rim, what size tyres are people running with R34 GTR rims?
cheers
darren
Thanks mate, I'm happy with them... I'm running 235/40 so there is a bit of stretch. I Could have gone 245 but there isn't really much room to play with as the rear is quite low.
You should be right with those specs, The rear will be close to flush but fronts as u know are 25mm narrower - I've previously run a 9 +38 with a 245/45 which was too close to the strut...with the factory struts I think u have less clearance so maybe go a 245/40 :thumbsup:
Edited by adey88
My S1 with TE37s (33 GTR offset: 17x9 +30) using 20mm spacers to make the front the same as the rears, Tyres Contisport 3 255 40 17. I will be going a tad lower still but tyres will tuck in as I have adjustable camber arms front and rear (mainly for my slicks but I won't bother putting them back to stock during the summer).
for anyone interested in some varrstoen wheels, heres a reply i recieved from them today
19x9.5 +22 fits great on a stagea ,
We have them landing in december for $1295 +80 del to VIC
And with Federal 595 evo tyres $2495 delivered
sorry i should have put varrstoen 2.2 wheels so u know which ones they are. they look like then ROTA Grid wheels
Our Nissans are 66.1 centre bore. Unless you get some Nissan specific rims most aftermarket items have a centre bore of 73.1mm.
You can get plastic locating rings but better to get metal ones like this:
http://www.trademe.co.nz/motors/car-parts-accessories/wheels-tyres/other/auction-421179978.htm
+15 will stick out somewhat - you'll have to deal to your guards (see the pic above #342 of my car with +30 - ---+15 will stick out half an inch more and my gaurds have been pushed out about 20 mm
1321012210[/url]' post='6105856']
Found some cheap GTR fittment wheels. 18x9 +15. Am I correct in thinking they will fit my rs4s? Need an answer ASAP please!! Cheers guys.
A +15 will look good - you may need to slightly roll the rear guards (depending how low u are) but since it's a manual you should ave more room to play with.
What wheels are they anyway?
post-81631-0-58801500-1321071878_thumb.jpg Yeah I just did a heap of reading through here and found a white rs4s running 18x9.5 +15 with 8mm slip on spacers for the rear to gain strut clearance on page 11 and it looks perfect. The wheels I'm lookin at are only 9" so that gives me 7mm more clearance inside and out. Shouldn't need to run a spacer and don't want to! I'm still at stock ride height (much to my dismay!) haha. I believe they're a Lenso D1r... Edited by BMX666
So you got the varrstoen's then? I've been keeping an eye on everything Stage on here for a while now hahaha. I'll find out if i got mine tomorrow.... Just need to drive to Sydney (about 600k's) to get them, then put tyres on them! Looking forward to the pics tho...
They should look good on the stag, looks like they have a bit of dish too!! If you coming to sydney to get tyres check out Tempe tyres, they are usually cheap and have stock of most tyres (I have no affiliation with them btw) :)
Nah I'll get tyres locally down here. Just have to drive up to pick up the rims. Going to be a big day if I get them!! I know Tempe and I know they're good. Although I've been stuff around by them in the past when getting wheels for my 5L VQ Statesman. Probably wasn't all their fault as I was in a rush and they kept saying they're coming they're coming for about 3 weeks. Ended up getting the same wheels in a different color, cheaper and in about 3 days from somewhere else. Although they had the sane bank account so I guess they still got my cash in the end. Haha. 7 day wheel and tyre or something like that. I'd give Tempe another go if I wasn't in a rush tho. Not dissing them at all.
i didnt get the varrstoen wheels. i got some Koya Endless wheels custom made to my offset choice they are the blackwheels with chrome inserts.they arent bad,not really as jap spec as id like, but meh $1800 for the wheels and tyres is not a bad price.
  • 3 weeks later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
