put some new wheels on the 260 today,decided i was getting bored with the 18x8.5 bbs wheels so replaced them with Rota Fighters supplied by option 1 garage, 18x9.5 +20. next step will be to fit some coilovers and adjustable arms.
sorry bout the iphone pics.
the new wheels
The old BBS
The service form O1G was excellent, They had some brand new genuine Dayz carbon inserts for around the ac vents there if anyone is looking for them!
In terms of 'being legal' and meeting VSI, is fitting 245/40/18 on 18x8.5 on a s2 c34 auto okay?
Depends entirely on offset wheel poke and track change wise
Google tire size calculator or go to WWW.willtheyfit.com and chuck in your stock size
But probably yes but maybe a 235/40 will be closer
Thanks, Also found this http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP11_Section_LS_Tyres_Suspension_Steering_V2_1Jan_2011%20v3.pdf page 20+ refers to some legal fitment condtions.
Looks like i am good with my size. I just like to know sure for insurance purposes, incase they say, those tyres arnt legal, ur car isnt road worthy, no money for you.
Does that ever happen? Insurance claim denied because of unroadworthy vechile from mods like wheels?
Looking at upping tyre size on ours (along with a few other things), reckon 18x9 +20 with 265/35R18s will work under an S1 stag, without flaring? Can lip guards, happy to fit camber arms etc if need be.
245/40 will be a great deal cheaper being factory fitment to falcodores with 18's
Have 235/40R18 now so 245s are barely worth changing to. I do suspect I would notice the increase in front end grip with 265s.
Thanks Zorro, sounds like it will be a pretty safe option as I should have 10mm or so more clearance to the guard.
  • 3 weeks later...
New Stagea owner and looking for some info on wheels.
would this size fit on my 2001 RS4S?
18 x 9.5, 5 x 114.3, +20
yes if you have coilovers and cambers arms on rear and you might wanna look into getting longer rear wheel studs...
Yeah should be pretty good
I think the flush figment for an Rs4s is 9.5 +12 so you wouldn't be far off there
Go back a few pages to see some examples as there were some recently
It will be the same figment as an 260rs too I think
Edited by pipster11
  • 3 weeks later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
