Mine is a 2000 but I highly doubt that would make any difference. If you go back a heap of pages there's a s2 rs4s running 18x10 +15 with coilovers. That's even less clearance than 9.5 +12 and he doesn't seem to have an issue. Maybe pm him?
at this point all i can do it get the wheels here and fit them up, see what happens and fingers crossed.
if they dont fit i will probably ask someone with an RS4S to trial fit on theire car to see whats different.
Good place to start I'd say. And also 235 won't really give you any more clearance than 245. Both are stretched do they'll angle away from the rim edge, but they're both still locked into the rim at the bead which means theoretically they would be the same. Get my point? Just depends on how much stretch and how much road contact you want I guess. Just another thing to think about.
yeah, havnt decided on the tire size yet, all going to depend if i need to run spacers on a wheel which will sit 60 mm out from where im at now and the guard fitment becomes an issue,
a little streatch is good for look sbut i dont want stupidity, eitherway the tire wont be what will contact with the strut.
I have 19x9.5 +12s all 'round, with 245s, 35 profile I think and coilovers on a 99 rs4s.
Perfect guard clearance and a couple of mm on the strut in the rear.
Was pretty sketchy when i ordered them.
Have had them on the car for 20000k now, no dramas....
Mind you, mines not as low as yours, so not as much rear camber pulling the top of the rim in closer.
I had trouble getting standard skyline rims (V35) to fit without spacers to get rego.
I ended up having to use some scabby R32 rims on for rego.
wheels should arrive soon, i was hoping today.
i have been doing some more digging.
firstly:
Can anyone CONFIRM for me the width of the standard R34 GTT 17" wheels
cannot seem to confirm if they are 17X7+40 or 17X7.5+40??
7.5 =]
which means i will be gaining clearance.
also i have been mashing through the 55 page stag suspension thread.
realising i have several degrees of - camber. i am ordering camber arms which will straighten the wheels back up and give more clearence from the strut again so this should be fine, they should fit without spacers.
i hope :ph34r:
It must be the camber you've got because I'm also running 18x9.5 +12's with 245 45's and no issue at all. stock suspension with nismo springs
is that to me?
new wheels noton yet but yes the camber must be my issue at the moment as the current wheels fitted beffore the coilovers went in. camber arms and new wheels this week i hope
yeah sorry i was replying to you ghost. That's interesting to know if i go adjustable suspension later on, that i'll be limited my my wheels. food for thought.
hope you get it all sorted.
OOOOK
test fitted the wheels today and if it does fit its gonna be seriously snug.
ok so outsude fitment is going to be nice
Front
Rear
however as you know im worried about the strut clearance.
fronts clears everything as far as i can tell
the rears are not
remember this is in the air
i cant fit my finger between them.
ok so the camber is the first issue
this WILL be fixed with camber arms
as it is the hub falls 10mm inwards when loaded up
their is NO way these work without spacers with the current camber arms.
im going to need to run no camber and see if it clears over bumps and around corners.
failing that spacers then slight camber into the guards
tires go on soon and camber arms should rock up any day now.
will roll the lips and hope i wont need to pull the inner guards out.
OOOOK
Front
Rear
the rears are not
I came across the same problem i had 245/40/18 tyres on 18x9.5 offset 20 on rs4s rear and once i had the suspension underload the tyres use to scrap the coilovers, you could set the camber to almost no camber at all, but personally it looks too weird for me, so i ended up getting longer nismo wheel studs, spaced out the wheel and getting the camber right and 225/40 tyres..
Edited by shotpointblank
im going 235/40 tires, i really didnt want to go spacers, i really didnt.
hoping i take some caber away and run about -1deg and it wont touch under load.
under load now it gains f**king heaps of camber with the stock arms
im so confused, noone with an RS4S with 18X9.5 +12 has had this little clearance. why mine?
i.e.
Just took a pic of mine for you (sorry it's sideways, uploading from phone and it rotated it). As you can see there's quite a bit of clearance with the stock shocks, I'd say a good 15mm. Obviously BC's are thicker though. I'm not sure how much but you can work that out. Mine is as stated earlier s2 rs4s running 18x9.5 +12 with 245 40's.
Edited by GH05T
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
