On 9/19/2019 at 1:45 PM, ESSEJ said:
Reviving an oldie!
Dear wheel gods,
I'm eyeing off some enkei 17x8 +38 for my S1 dayz manual converted...
Will they fit??
Cheers
Here is my S1 with some no -name rims I was using for the track . They were 17 x 8.5 offset +17 so fit the body ok but whether they clear the brakes depends on the profile. I had previously had some Enkeis on the car so chances are good. Are you close enough to test fit?
Sorry - it was a few years ago now...I think I had 10mm spacers on the back and possibly 20mm on the front....
  • 9 months later...
6 hours ago, touchmyDDz said:
Hi I've got a c34 rs rwd just wondering if any one is run rota d2-ex 18×9.5 15 offset before I spend 2 grand on rim's that dont fit
I would guess not. To be sure find such a wheel and trial fit it OR look at the wheels on your car check the width and offset and make the calculations to see where they would end up.
Below my C34 with 18 x 8 +30
So, I searched "backspacing"and this came up, but somehow couldn't find it in the text... anyone know what the backspacing is (i.e. distance from wheel mounting face to coilovers) on a 2000 WGNC34 260RS (MT)?
I have an R34 face so I can't (immediately) tell if it's a S1 or an S2, but I assume it's a S2.
My car is about to come with 9.5J +22 with 3mm spacers (i.e. 9.5J +19), and I assume the spacers are there for backspacing rather than poke, since I only just learned that the rears don't have much space!
I was told/read that 9J +15 should fit, but close.
I originally wanted to run Z34 19*10.5J +23, and thought I'd need at least a 20mm spacer in the rear for that, plus some gnarly camber to fit them within the guards -- especially if I run the 255/30-19 that I intended to.  But now I'm worried it might be a 25mm spacer, which would mean, basically, Overfenders... which aren't tenable.
Does someone have the actual distance so I can calculate on paper before taking delivery of the car?
Much appreciated!!
  • 2 years later...
  • 5 months later...
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
