Bee*R and URAS both make kits to change the R33 front to R34. Bee*R's is a complete kit (front/side/rear) wheras the URAS one is just the front.
Both look hideous. With the price of R34's these days you can buy a R34 GTt cheaper than you can get an R33 for and convert to an R34 front.
yeah, same site as above but direct link to r334
http://www.bee-r.com/main/parts/aero/b334r01.htm
Looks awesome. I'd do it in a second if I had the money.
Anyone know anything about the wing on that car? I like the look of that...
  • 2 months later...
hey the motorkitz one was just under $3800 from memory as i was looking into it msyelf, that was for the wide rear gaurds aswell kit included fibreglass bonnet, front bar, sideskirts, rear bar, lights i think it looks cool but i think the hidden costs involved far outweigh the "coolness/worthit"
h i wouldnt agree, if i were to do it it would be because it isnt so common, its getting harder these days to make a car different this is a more agressive way of achieveing that. it is quite expensive so it isnt for everyone, and sure its possible to just buy a 34gtt but we theres a wow factor to the 34 front on 33. my opinion only, 34 front is not for everyone
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
