"It's gotta all around stage 1 performance set" lol someone's been playing too much NFSU! :D
"talked to the police they're willing to let that slide" hahaha
From his main page..
"LOL one of my comps got hacked and destroied so had to get a new one....that one got hacked and destroied....got another one(this one) and my guess is it ain't gonna last to long." Funny that..
"Current Residence: N.W. Custom Motoring, Shinjuku, Tokyo Prefecture or Miyuki Motors Export, Ibaraki, Osaka Prefecture" Sounds like bullshit to me since he says "still been travleing the northwest area of the states soon to be goin to the southern centeral states for work".. sounds very much like he lives in the USA to me.. Japan doesn't have states as such does it?
"Favourite movie: Seven Samurai, 2Fast 2Furious" uh-huh! that explains it!
"Operating System: Windos XP w/ NX nitros cooling system, Twin Turbo Skyline R-33 GTR motor, and 60lbs Boost"
"Favourite gaming platform: PS2 Japanese custom w/ a Kanji vinyl, Red Neon, stage 2 hydralics, NX cooling and NOS purge"
Am i the only one who thinks that looks like an R32 (filename has R33)? Is it meant to be a jap cop car?
Edited by cogs
K_S__R33_ID_by_Kuroi_Shi.jpg Am i the only one who thinks that looks like an R32 (filename has R33)? Is it meant to be a jap cop car?
yup... everything about that is an r32.
it's a gtr with cameras all over it to tape it's doings.
deviantArt used to be such a nice place about 4 or 5 years ago, all the people in the design community used to be on there... now its just a cesspool for emo's and msn kiddies and their attempts at "art".
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
