hi all
Ive just finished rebuilding my engine and got the car back on the road (now its off the road again cause some f**ktard ran into me :@) but I noticed that when I shut the engine off, there is a distinct hissing noise coming from the front left side of the car. I have checked all vacuum lines etc (cause thats what it sounds like) and cant find a fault.
Has anyone had the same problem or does anyone know what it could possibly mean?
Cheers guys
https://www.sau.com.au/forums/topic/92973-hissing-after-shut-down/
My car has similar sounds when you turn it off... it'll kinda hiss for a bit like there is a pressure releasing..
Makes a couple of other noices, ticks a bit than settles down and stops after 20secs or so.. I've got over it as I don't think there is anything wrong I think it's probably just the engine cooling..
Exact same thing on mine.. After a while the faint hissin noise goes away..
must be a series 2 thing..
but ive only got the standard nissan turbo.. well so I think anyways.. but the only thing is it wasnt doing it before the rebuild (forged rods and pistons + balance).  Is it anything to worry about??
mine did the same thing when I had the standard turbo.
Like a hiss whistle. I wouldn't worry. If your engine is running ok, then leave it be.
Mine is stock except from exhaust.. it still does it.. I wouldn't be too worried..
No need to worry.... as a few of you had said its just pressure release coming back through your pod. You can just sort of hear it if you have your standard air box in there, but its no where near as noticeable.
I even had a vtech civic that would hiss out the pod when you switched it off... No need to stress guys.
On the topic of noise's any1 have this on their car
After i got GFB Stealth FX BOV fitted i now can hear my turbo making a winding noise
not air suction noise. cant really describe it but i've heard the same noise on a WRX sorta like a humming only when im on boost sounds pretty cool. just wanna know if its safe
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
