Gary with your system you must run a cooler is this correct?? On the 3 or so  GTRs i intitially removed the hicas from I was simply blocking up the rear chamber, and the pumps would die I think due to over heating so I simply make sure I do a 2ws pump conversion at the same time, obviously its not needed if you run the pump the way you suggest!! Plus the 4ws pump is a mammout compared to the r33 pumps running a 2ws pumps looks better in the engine bay I think!!!
I agree, the R33 power steering pump is smaller, lighter and simpler. In an ideal world, it would be worth changing. But, in my opinion, the cost in both time and money is excessive for the benefit gained. Plus it makes it a far more complicated upgrade than simply swapping one hose around.
Most of the guys doing HICAS removal want a simple and quick elimination of the rear steering. Having to change the power steering pump, pulley, hoses and reservoir is a complication that might stop them from doing what is really necessary. ie; removing the HICAS itself.
Later on they can swap the pump etc over if they want, but it isn't necessary for them to get 99% of the benefit. The 1% from swapping the pump can be done later.
:mellow: cheers :(
is it a straight swap? or do you need a little bit of manufacturing to get it to fit?
You will need it's mounting bracket. The banjo fittings are at a different orientation to the 32's. And the pully is a 3-rib (the R32 is a 4-rib)
Anyone wants one, I have one from a Stagea. PM if you are interested.
R32GTR's and R32GTST's have a cooler on the power steering standard.  It is a simple loop of aluminium pipe, but it works.  On the race R32GTST I have used a standard Stagea auto transmission cooler as the power steering cooler.  Works a little better.
:D cheers :blink:
isnt that cooler (tube loop with fins) part of the hicas plumming? so it would cool the fluid running through the hicas. I know they share the same resevouir, but now that the hicas is gone, a lot of the heat will also be gone. So the ps wouldnt get that hot?
I too have a auto trans cooler which i might use instead of the stock cooler, only cause it looks nicer!
thanks
steve
thanks
steve
Hi Steve, I don't know how much total heat the HICAS adds. I reckon maybe none, as what heat it adds would be dissipated by the long run underneath the car in the steel pipework.
All I know is, the first GTR I removed the HICAS on, boiled its power steering fluid at a track day as it had no cooler. Ever since then I have run a cooler on all R32's and not had one problem.
:blink: Cheers :blink:
  • 3 weeks later...
with that being the case am i right then in saying that for a 32 GTR a tomei hicas lock kit is an easier/neater option?
I was going to go the lock bar route and like the idea of the weight saving, but i don't particularly want to fark around with the power steering too much. The tomei kit is a just 2 shims and a little module to cure the warning light/heavy steering problem.
I just used some metal washers to lock the rear rack on my R32 and then the sydneykid power steering mod to make sure the pump didnt poo itself. Worked a treat and cost like 50 cents.
Not sure why people go out and get Hicas lock bars when the factory bar with washers seems to work just fine.
SK - I'm pretty thick so sorry for asking this - which you have probably been asked a million times.. by looping the two lines that WERE going into my HICAS unit - is this running the fluid through the cooler? Cos I really have no idea where this cooler is... and this is how my current setup is going... just looping the lines..
Looping the lines is fine, the rear stage of the pump is just pumping the power steering fluid all the way down to the back solenoid, then back to the front solenoids and through the cooler.
The cooler itself is a simple loop of aluminium pipe, just in front of the radiator on the drivers side.
By doing that you are disconnecting the HICAS OK, but you are not saving the 20kgs or so of weight. That's the only additional advantage of removing the complete system.
:) cheers ;)
i have a question if hicas is there to help cornering why is it so many people want to remove it
about the only thing i have heard is the when taking tight lines the car tries to correct you, then you correct the car, then the car corrects .....
but what ever happened to slightly adjusting your driving style to work with hicas??
tell me if im wrong cause i dont really get it
i own a GTR and will look at doing some club level track days
so why is it better to remove hicas?
RellikZephyr
RellikZephyr
Firsrly HICAS is not there to "help your cornering", HICAS is there to try and make the casr understeer at all times when sdriving at 9/10ths. Nissan designed it that way as it is safer for the Wallies. When they get into trouble the HICAS is supposed to make the car understeer, so instead of spinning off backwards they plough straight ahead. The ploughing action itself reduces the speed, so if they do go off they hit things at a slower speed and the front airbags/seatbelts work. If you spin off backwars/sideways, the airbags and seat belts have less chance of saving the Wally's ass.
Back to your question, you have got it......."when taking lines the car tries to correct you, then you correct the car, then the car corrects........." So instead of a nice smooth line around a corner at 10/10ths, it ends up being a sequence of jerks and corrections. If you are already at max G force, the jerks will cause the car to loose traction completely. So you have slide, correct, slide, correct, this is both detremental to lap times and confidence sapping.
Adjusting your driving style doesn't help, all it means is you have to go slower or suffer the momentary losses of traction. You can't control the car accurately with the throttle or the steering wheel when this sort of stuff is going on.
I have never ever seen a Skyline race car with functioning HICAS, once you have tried it you will understand why.
Hope that clarifies
:O cheers :)
  • 4 weeks later...
Gary - mind if you post a couple of pics of this looping you speak of?
Which looping? There are three possiblities;
1. The loop of aluminium pipe that serves as the standard cooler?
2. The loop where the front solenoids used to be, to feed the fluid through the standard cooler?
3. The loop at the rear to bypass the rack?
I will have to take some pictures of my own car, I don't actually have any, either before or after HICAS removal.
:) cheers :)
As far as I can tell, the loop at the rear is just a bit of U shaped pipe - I can figure how that goes,
Moreso, when you pull out all the associated rear piping, where to hook the remaining rear stage piping up to the aluminium pipe.
So 2, and 3, above :)
Thanks again
what do people think of this solution???
its the tomei kit, but does it cause any problems with the pump in the long run?
http://www.tomei-p.co.jp/_2003web-catalogu...thers_rset.html
As part of the Tomei kit install you disconnect a plug under the bonnet. This in addition to fitting the washers & the small electrical unit. Unfortunately I don't understand all the instructions (They are in Japanese) so don't know exactly what it is you are disconnecting...
Can anyone help?
Used to be very popular, locks the rams on the rear rack in their outwards position. So there is still power steering fluid circulation, but no steering action. The box plugs into the HICAS ECU and stops the dash light from coming on.
Quite effective, no long terms issues, they are just expensive for what they are. Plus they leave all the hardware in place (and even add a little bit) so no weight saving.
:D cheers :D
PS; make sure you get English instructions as they are tricky to fit, particularly the washers.
Edited by Sydneykid
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
