FINALLY!!!
sorry for the delay boys and girls
ZERO glare, all sweet, sweet cut off
needless to say I am rapt with this...
man you deffinitely should be rapt that looks PIMP as it comes!!!! i was attempting to put a strobe light kit in my 32 gtr and acccidently drilled the parker globe little plastic lens inside the headlight loose and it now shakes round everywhere. im so glad you posted how to seperate the two parts of the headlight your a champ!
i do but have two questions that you probably answered in there somewhere what did you re seal the headlight back together with? just black sellastic. And did you ever find out where to source these angel eyes from?
Awesome thread man great DIY opened my eyes to customisation i never thought of!
respect
Dion
FINALLY!!!
oh one more quick question how did ya get all the old crappy sellastic off? i have been cutting it off the glass side with a razor but scared to do it to plastic cause its my only headlight and dont want to mawl it!
thanks mate much appreciated
First off Ronin 09 that looks awsome and i have been keeping a eye on this thread and it has inspired me to do the same thing as you but i have been have a lot of trouble finding the Euro HID projectors so if you or anybody else could help me out with this that would be great
FINALLY!!!
Holy crap!
Its good to see these working finally, ive been subscribed to this thread for going on 3 years
The only questions though are: When will you start selling them, and how much? :)
  • 3 weeks later...
  • 3 months later...
an update - the LED parkers that I had in both sides have carked it.
if you do an LED change, I suggest an in line voltage reg as I think that's what killed them...
may have to do a mark 2 version after all!!
  • 1 year later...
  • 9 months later...
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
