Started my retrofit today. Morimoto FX-R projectors are almost the same as R32 projectors. Tapped one corner and drilled the other, went straight onto the adjusters. Tap: 5mm dia 0.8mm pitch (M5x0.8). Need AMP to D2S straight adaptors, which I didn't order beforehand so my retrofit is on a hold :(.
So finished up at 3am lol started at 11:30pm
Standard R32 - Morimoto FX-R
Tap this existing hole with M5x0.8mm
Drill then tap the bottom right hole
What you end up with
As you can see, the FX-R is a bit shorter than standard. You can make up a mounting plate to offset the difference, but the gap doesn't bother me.
4300K cheap bulb and cheap LED parker. Note the parker is more than 6000K i.e. blue
Need to adjust it a bit more. The hole you drill will determine the angle of the beam as well. When I do another set I'll put more effort into where to drill the hole.
Crap picture, but they are so much more better than standard R32 projectors, as expected. Can actually see the road.
I'm going to put the fault with the bulbs for the uneven spread. High beam is awesome.
I've kept the standard halogen high beam so I can flash during the day. But when the shield drops, you can barely see the halogen. They are 85W, which I'm assuming is factory as both my projectors has them.
Edited by niZmO_Man
images rehosted
Here is a crappy pic of the second set I did. Painted the cover thing to make it look like R31 style :P
On 25/03/2013 at 11:17 AM, BWRGTR said:
awesome work, do u know if there are any options with N1 headlights, i believe it uses reflector rather than projector?
perhaps fog lamp in headlight can be done as a projector
Get a pair of projector headlights and sell your N1s (they are more valuable). You can retrofit the Morimoto Mini H1 (or D2S) into reflectors, but pointless really.
  • 2 months later...
I will be doing this to my R32 headlights when I get the chance (when I get off my ass)
Does retrofitting these HID projectors onto the headlights make them LEGAL and still retain the self-cleaning/adjusting mechanism?
They don't have self leveling, hence the cheap price. If you want OEM spec, be prepared to pay $1k+ for used headlights + parts. You will then have to put the squirters on your bumper (self cleaning). Self leveling is built into the projectors so it shouldn't be too hard to wire up.
^ I guess if they are smart enough to realise that it isn't stock. Some r32s had OEM projectors and others just non-projector types. You could feign ignorance saying it was stock OEM projectors but upgraded bulbs.
But seriously I have the stock crappy non-projector type - and nowadays I reckon I'm the odd one out coz I'm surrounded by projector types...
Yep. You can fit all the auto leveling and squirters, then have it engineered and they can still defect you.
But you're better off doing a retro with a Morimoto projector and 4300K bulb. Just aim them properly. Much better and far less glare than putting HID kit into a halogen headlight.
If you put anything higher than 5000K you deserve to get defected. Same goes with higher wattage. 35W is plenty, if you need more and you're driving around town, you need new glasses or stick to daytime driving.
Remember ALL OEM HIDs are 35W and have 4200-4300 K bulbs (unless you have a Merc, I believe the S class comes with 5000 K Osram bulbs).
I've seen far more projector headlights than reflector ones on an R32, so you have an uncommon/rare car ;). Put some Blue plus 90 bulbs in, or grab a pair of projectors and retrofit them ;)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
