UPDATED 1 JUNE 2007. STAY TUNED FOR SOME MORE ADDITIONS!
Headunit Installation
Virtually identical for all but here's discussion for
R32
R33 - with links to pics
R34 - courtesy of r34gtt.net
Stagea
Wiring up your headunit
Nissan Wiring Harness information - verified as correct by me :D
Need a DIN pocket?
Just head to your local Nissan dealer. Any post-1996 Nissan car (eg N15 Pulsar) will have a DIN pocket that will fit in your Skyline.
Antennas
Jap - Aussie antenna conversion - you need an adaptor. The Aerpro AP348 is $15 from any stockist (Autobarn, etc)
Can't pick up radio on a Japanese headunit?
If your headunit reads on the Japanese FM frequency (~75-90kHz), you'll need a frequency/band expander to compensate. Pick one up from your local car audio store - the Aerpro AP745 costs $19.
That, or get a new headunit :)
Sound Deadening
It's one of the most effective ways to improve the sound in your Skyline! If you're outside your car, knock the body panels and listen for that hollow 'tin can' reverberation. I'd go so far to say that deadening at least part of your front doors is mandatory if you are concerned about decent sound.
https://www.sau.com.au/forums/topic/94069-car-audio/
  • 1 year later...
Speakers
The factory speaker sizes were as follows:
R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there)
R33 - 6.5" front/rear - mounting depth is approximately 57mm (as measured by me!)
R34 - 6.5" front/rear - deep speakers are not a problem. There are no constraints with mounting like the 33.
6x9s will fit in the back fairly easily, need a spacer.
6x9s will fit in the fronts not so easily (again you'll need a spacer), but still doable.
Predator's spacer template for front R32 speakers
Changing rear speakers in your Cefiro
Changing rear speakers in your R32 (including parcel shelf removal)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154957
Subwoofers
Wiring up your subwoofer
There are plenty of ways to wire up a subwoofer, depending on how many subs and amps you have, their configuration, etc. Crutchfield has put together a fantastic guide which shows you how to wire up as many as four subwoofers to your car. Check it out at the following link:
http://www.crutchfield.com/learningcenter/...ers_wiring.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154964
Troubleshooting
Help! I've installed my system and now I get a whining / hissing sound from my speakers!
Wayne Harris has written a fantastic article which covers most types of noise, and contains step by step information on how to isolate the problem in your car. It is a MUST READ if you are trying to troubleshoot. Read the article here: http://www.termpro.com/articles/noise.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154970
  • 8 months later...
Wiring Diagrams (care of Chris Rogers)
Tacho addition:
http://www.apexi-usa.com/pdfWiring/3.pdf
(this is the current RSM diagram - gives speed ,tach,ign wiring off ECU)
R32 - RB20
P23 diagram:N4a
R32 GTR - RB26
P23 diagram N4B
R33 - RB25
P23 Diagram N4C
R34 - P23 also :D
R32 stereo wiring
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
when following this diagram the black wire on your radio goes to frame! nowhere else.
R33 stereo wiring - SEE R32
R34 Stereo Wiring
use the 2nd diagram. for R33 S2 - use 2nd diagram.
V35/M35 base spec:
2nd diagram. DO NOT attempt this on a BOSE VERSION! it has an ENTIRELY DIFFERENT SETUP and you WILL kill something. cars later than 05 are CANBUS so be VERY careful here.
34 GTR display info inc swapping to non GTR dash.
Here's a good guide for transplanting the MFD into an ER34.
http://flatout.main.jp/driving/parts/bnr34mfd
Here's an excellent guide for transplanting the MFD into an R33
http://www.geocities.jp/yossyi_bcnr33_carbon/inpure/MFD.html
An AV cord to output TV onto the MFD (Clarion part #:855-5430-00)
http://pub.ne.jp/BNR34/?entry_id=89518
MFD pinouts
http://f14.aaa.livedoor.jp/~lindwurm/bnr34/diy/mfd/mfd.htm
PIVOT START BUTTON
http://www.pivotjp.com/download/download-e.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3629119
  • 3 months later...
R32 Owners:
If your planning on installing Amps and Subs, something you seriously need to think about is the grounding system in your car.
The standard grounding system in the R32 (I am using a GTR as my reference point) is adequite for a headunit, and for the standard Skyline electrical system, but if you add high powered audio amplifiers, D-class monoblocks, and other hardware, then the stock grounding from the battery will be insufficient to power your gear.
The biggest give-away that you have a grounding problem is that horrible engine noise that you sometimes get through your speakers, this is caused by the Alternator powering your device instead of the power feed coming from the battery.
Electrical Theory:
Basically, Electrical current (against popular thought) actually pushes the electrons FROM the positive terminal or power feed TO the negative terminal or Grounding point. If the grounding point is not up to the demand, then the Positive feed can not push out as much amperage.
If your system is a sh1t-hot system, but you have the stock 8-gauge grounding fromt he battery to chassis to engine block, and your running a 4-guage power feed from the positive terminal to your amp(s), then when the system gets cranking, the system will bottle-neck at the 8-guage battery - chassis ground, and start demanding power from somewhere else that can both feed and ground adequitely.
Guess what, the only other powersource in the car that can possibly meet the demands of your high-end audio gear is your alternator, so the system starts feeding from power from the Alternator as well as the battery, and thus, you have engine noise.
How to fix this problem:
Head to the local Jaycar/JB Hi Fi, Dick Smith Electronics, Etc, and get yourself a car battery terminal that will fit your battery. Next, get yourself either 4-gauge, or even some 0-gauge wire, probably about 2 meters will be sufficient, and your set to start work.
Basically, you need to remove the current grounding from the battery to chassis to engine block, and replace it exactly as it's installed currently, but with the thicker wire.
Remeber, current needs a clean path, so have some sand paper on hand, and where the cable gets grounded to the chassis, clean the metalic area completely until it's beautiful and shiny, then strip back the cable sheith and bolt down the cable (I like to use some clear-coat once this is done, to provide a barrier against oxygen getting into the freshly sanded metal and attracting a rust-spot).
The bitch is grounding to the engine block, but with some patience and time, you will be able to get under the throttle body and undo the current ground and replace.
This will resolve 90% of engine noise from from an R32 GTR's audio setup, if you still have engine noise, you haven't grounded the amplifiers correctly, but that's for another How-to or informational thread.
Thanks.
B.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3867910
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space?
with ever increaseing range of flat subs you should be able to purchase a good sounding sub that wont take up much room.
these go fairly well http://kicker.com/compvt_subboxes <--- you can get them pre boxed in 8" 10" and 12" or you can get the subs on there own in the same sizes as well as a 6.5 inch which would need a custom box, or you could mount it in the rear speaker slots.
pioneers version also goes well. http://www.pioneer.com.au/en/Products/Car%...Subwoofers.aspx (scroll down they are there, however i couldnt be botehred to find pre boxed versions but they do exist) these are from a 8' to 12" only as far as i know.
i beleive a few other brands have had a go, but these are the only 2 i have actually heard and seen playing.
so if you like your boot space, these are the way to go.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4880065
  • 7 months later...
Thread from the dead.
Regarding subs in an R34, yes there is HEAPS of room wtf are you guys on about lol.
If you have a factory 17" mag instead of a space saver and your no longer using the plywood sheet there is a nice spot on the left hand side (the wider wheel sits up more creating a nice slot either side) that will fit a 12" sub in an average size sub box. (warning don't put a large box there as it may move in the way of the hinge locking the boot shut, but a normal size wont)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5238263
  • 2 months later...
2009-2010 R35 GTR Alarm diagram
MODEL YEAR(S) GT-R 2009 -2010 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 PART COLOR LOCATION 12 VOLT CONSTANT GRAY (+) 40 AMP @ BCM, (BLACK, 3-PIN PLUG), PIN 1, NOTE #2 STARTER BROWN (-) @ PUSH-BUTTON IGNITION Switch or BCM, (BLACK, 40-PIN PLUG), PIN 18, NOTE #2 STARTER 2 LT. BLUE (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 21, NOTE #2 IGNITION 1 RED (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 11, NOTE #2 IGNITION 2 YELLOW (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 16, NOTE #2 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 31, NOTE #2 ACCESSORY/HEATER BLOWER 2 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 24, NOTE #2 KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, (WHITE, 10-PIN PLUG), PIN 8 POWER LOCK PINK (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 17, NOTE #2 POWER UNLOCK BROWN (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 20, NOTE #2 DOOR TRIGGER GRAY (-) @ BCM, (GREEN, 40-PIN PLUG), PIN 39, NOTE #2 DOMELIGHT SUPERVISION PURPLE (-) @ BCM, (WHITE, 16-PIN PLUG), PIN 16, NOTE #2 TRUNK RELEASE GREEN (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 36, NOTE #2 SLIDING POWER DOOR N/A HORN WHITE (-) @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 8 TACH LT. BLUE (AC) @ POWER STEERING CONTROL UNIT, (WHITE, 12-PIN PLUG), PIN 10, NOTE #3 WAIT TO START LIGHT N/A BRAKE PINK (+) @ BCM, (GREEN, 40-PIN PLUG), PIN 7, NOTE #2 FACTORY ALARM DISARM DISARMS from FACTORY REMOTE ONLY!! ANTI-THEFT NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 EXTRA INFORMATION NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 or XK07 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located in the PASSENGER KICK PANEL. NOTE #3: the POWER STEERING CONTROL UNIT is located under the PASSENGER DASH, behind the GLOVE BOX.
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356276
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
