UPDATED 1 JUNE 2007. STAY TUNED FOR SOME MORE ADDITIONS!
Headunit Installation
Virtually identical for all but here's discussion for
R32
R33 - with links to pics
R34 - courtesy of r34gtt.net
Stagea
Wiring up your headunit
Nissan Wiring Harness information - verified as correct by me :D
Need a DIN pocket?
Just head to your local Nissan dealer. Any post-1996 Nissan car (eg N15 Pulsar) will have a DIN pocket that will fit in your Skyline.
Antennas
Jap - Aussie antenna conversion - you need an adaptor. The Aerpro AP348 is $15 from any stockist (Autobarn, etc)
Can't pick up radio on a Japanese headunit?
If your headunit reads on the Japanese FM frequency (~75-90kHz), you'll need a frequency/band expander to compensate. Pick one up from your local car audio store - the Aerpro AP745 costs $19.
That, or get a new headunit :)
Sound Deadening
It's one of the most effective ways to improve the sound in your Skyline! If you're outside your car, knock the body panels and listen for that hollow 'tin can' reverberation. I'd go so far to say that deadening at least part of your front doors is mandatory if you are concerned about decent sound.
https://www.sau.com.au/forums/topic/94069-car-audio/
  • 1 year later...
Speakers
The factory speaker sizes were as follows:
R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there)
R33 - 6.5" front/rear - mounting depth is approximately 57mm (as measured by me!)
R34 - 6.5" front/rear - deep speakers are not a problem. There are no constraints with mounting like the 33.
6x9s will fit in the back fairly easily, need a spacer.
6x9s will fit in the fronts not so easily (again you'll need a spacer), but still doable.
Predator's spacer template for front R32 speakers
Changing rear speakers in your Cefiro
Changing rear speakers in your R32 (including parcel shelf removal)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154957
Subwoofers
Wiring up your subwoofer
There are plenty of ways to wire up a subwoofer, depending on how many subs and amps you have, their configuration, etc. Crutchfield has put together a fantastic guide which shows you how to wire up as many as four subwoofers to your car. Check it out at the following link:
http://www.crutchfield.com/learningcenter/...ers_wiring.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154964
Troubleshooting
Help! I've installed my system and now I get a whining / hissing sound from my speakers!
Wayne Harris has written a fantastic article which covers most types of noise, and contains step by step information on how to isolate the problem in your car. It is a MUST READ if you are trying to troubleshoot. Read the article here: http://www.termpro.com/articles/noise.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154970
  • 8 months later...
Wiring Diagrams (care of Chris Rogers)
Tacho addition:
http://www.apexi-usa.com/pdfWiring/3.pdf
(this is the current RSM diagram - gives speed ,tach,ign wiring off ECU)
R32 - RB20
P23 diagram:N4a
R32 GTR - RB26
P23 diagram N4B
R33 - RB25
P23 Diagram N4C
R34 - P23 also :D
R32 stereo wiring
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
when following this diagram the black wire on your radio goes to frame! nowhere else.
R33 stereo wiring - SEE R32
R34 Stereo Wiring
use the 2nd diagram. for R33 S2 - use 2nd diagram.
V35/M35 base spec:
2nd diagram. DO NOT attempt this on a BOSE VERSION! it has an ENTIRELY DIFFERENT SETUP and you WILL kill something. cars later than 05 are CANBUS so be VERY careful here.
34 GTR display info inc swapping to non GTR dash.
Here's a good guide for transplanting the MFD into an ER34.
http://flatout.main.jp/driving/parts/bnr34mfd
Here's an excellent guide for transplanting the MFD into an R33
http://www.geocities.jp/yossyi_bcnr33_carbon/inpure/MFD.html
An AV cord to output TV onto the MFD (Clarion part #:855-5430-00)
http://pub.ne.jp/BNR34/?entry_id=89518
MFD pinouts
http://f14.aaa.livedoor.jp/~lindwurm/bnr34/diy/mfd/mfd.htm
PIVOT START BUTTON
http://www.pivotjp.com/download/download-e.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3629119
  • 3 months later...
R32 Owners:
If your planning on installing Amps and Subs, something you seriously need to think about is the grounding system in your car.
The standard grounding system in the R32 (I am using a GTR as my reference point) is adequite for a headunit, and for the standard Skyline electrical system, but if you add high powered audio amplifiers, D-class monoblocks, and other hardware, then the stock grounding from the battery will be insufficient to power your gear.
The biggest give-away that you have a grounding problem is that horrible engine noise that you sometimes get through your speakers, this is caused by the Alternator powering your device instead of the power feed coming from the battery.
Electrical Theory:
Basically, Electrical current (against popular thought) actually pushes the electrons FROM the positive terminal or power feed TO the negative terminal or Grounding point. If the grounding point is not up to the demand, then the Positive feed can not push out as much amperage.
If your system is a sh1t-hot system, but you have the stock 8-gauge grounding fromt he battery to chassis to engine block, and your running a 4-guage power feed from the positive terminal to your amp(s), then when the system gets cranking, the system will bottle-neck at the 8-guage battery - chassis ground, and start demanding power from somewhere else that can both feed and ground adequitely.
Guess what, the only other powersource in the car that can possibly meet the demands of your high-end audio gear is your alternator, so the system starts feeding from power from the Alternator as well as the battery, and thus, you have engine noise.
How to fix this problem:
Head to the local Jaycar/JB Hi Fi, Dick Smith Electronics, Etc, and get yourself a car battery terminal that will fit your battery. Next, get yourself either 4-gauge, or even some 0-gauge wire, probably about 2 meters will be sufficient, and your set to start work.
Basically, you need to remove the current grounding from the battery to chassis to engine block, and replace it exactly as it's installed currently, but with the thicker wire.
Remeber, current needs a clean path, so have some sand paper on hand, and where the cable gets grounded to the chassis, clean the metalic area completely until it's beautiful and shiny, then strip back the cable sheith and bolt down the cable (I like to use some clear-coat once this is done, to provide a barrier against oxygen getting into the freshly sanded metal and attracting a rust-spot).
The bitch is grounding to the engine block, but with some patience and time, you will be able to get under the throttle body and undo the current ground and replace.
This will resolve 90% of engine noise from from an R32 GTR's audio setup, if you still have engine noise, you haven't grounded the amplifiers correctly, but that's for another How-to or informational thread.
Thanks.
B.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3867910
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space?
with ever increaseing range of flat subs you should be able to purchase a good sounding sub that wont take up much room.
these go fairly well http://kicker.com/compvt_subboxes <--- you can get them pre boxed in 8" 10" and 12" or you can get the subs on there own in the same sizes as well as a 6.5 inch which would need a custom box, or you could mount it in the rear speaker slots.
pioneers version also goes well. http://www.pioneer.com.au/en/Products/Car%...Subwoofers.aspx (scroll down they are there, however i couldnt be botehred to find pre boxed versions but they do exist) these are from a 8' to 12" only as far as i know.
i beleive a few other brands have had a go, but these are the only 2 i have actually heard and seen playing.
so if you like your boot space, these are the way to go.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4880065
  • 7 months later...
Thread from the dead.
Regarding subs in an R34, yes there is HEAPS of room wtf are you guys on about lol.
If you have a factory 17" mag instead of a space saver and your no longer using the plywood sheet there is a nice spot on the left hand side (the wider wheel sits up more creating a nice slot either side) that will fit a 12" sub in an average size sub box. (warning don't put a large box there as it may move in the way of the hinge locking the boot shut, but a normal size wont)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5238263
  • 2 months later...
2009-2010 R35 GTR Alarm diagram
MODEL YEAR(S) GT-R 2009 -2010 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 PART COLOR LOCATION 12 VOLT CONSTANT GRAY (+) 40 AMP @ BCM, (BLACK, 3-PIN PLUG), PIN 1, NOTE #2 STARTER BROWN (-) @ PUSH-BUTTON IGNITION Switch or BCM, (BLACK, 40-PIN PLUG), PIN 18, NOTE #2 STARTER 2 LT. BLUE (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 21, NOTE #2 IGNITION 1 RED (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 11, NOTE #2 IGNITION 2 YELLOW (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 16, NOTE #2 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 31, NOTE #2 ACCESSORY/HEATER BLOWER 2 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 24, NOTE #2 KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, (WHITE, 10-PIN PLUG), PIN 8 POWER LOCK PINK (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 17, NOTE #2 POWER UNLOCK BROWN (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 20, NOTE #2 DOOR TRIGGER GRAY (-) @ BCM, (GREEN, 40-PIN PLUG), PIN 39, NOTE #2 DOMELIGHT SUPERVISION PURPLE (-) @ BCM, (WHITE, 16-PIN PLUG), PIN 16, NOTE #2 TRUNK RELEASE GREEN (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 36, NOTE #2 SLIDING POWER DOOR N/A HORN WHITE (-) @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 8 TACH LT. BLUE (AC) @ POWER STEERING CONTROL UNIT, (WHITE, 12-PIN PLUG), PIN 10, NOTE #3 WAIT TO START LIGHT N/A BRAKE PINK (+) @ BCM, (GREEN, 40-PIN PLUG), PIN 7, NOTE #2 FACTORY ALARM DISARM DISARMS from FACTORY REMOTE ONLY!! ANTI-THEFT NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 EXTRA INFORMATION NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 or XK07 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located in the PASSENGER KICK PANEL. NOTE #3: the POWER STEERING CONTROL UNIT is located under the PASSENGER DASH, behind the GLOVE BOX.
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356276
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
