Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Gentlemen, I'll be away on Holidays tomorrow. I'll be back on the 12th of December.
I'll be starting the prototypes then and I should have something to show soon after.
Cheers
BASS OUT
  • Replies 520
Hey guys.
The sample cuts didn't get done before Christmas, but should be ready real soon.
I'll keep you all in the loop.
BASS OUT
Would Like to get 1 for a Series 1, R33,
isit series 1? or 1.5?
not sure, 95'
stock front bar, (I think)
will get pic up asap.
I prefer it to be black? what is the best way to get it?
DIY paint job? :(
nice,
Look like my engine bay gona get some *bling *Bling,
hehehe
Thanks paul,
Yea I fink DIY pain job should be the way to go, coz atleast u know u f*** urself up, not some1 else, Or NOT : :lol:
That was acutally me sending that, but Paul was logged into my comp last night, and I forgot to log him off.
I oul suggest Anodising. beautiful finish.
I might actually offer it as a package in black or Silver....
Maybe
One of each for R33 GTR and R33 GTSt mate. Disgusted I wasn't automatically added. The povo R33 GTSt auto can bloody go without though :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
