Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
  • Replies 520
Hey ppls.
Sorry about the delay. This WILL happen. I'm just crazy busy at the moment at work.
Please bear with me.
I will be asking for monies to be deposited probably within a week or two before I get them made.
I'll post pics of the samples both on and off cars before this though.
Cheers Guys
BASS OUT
Trip was awesome thanks. Took in the best of the USA: New York, Niagara Falls, Washington, Boston, LA, Disneyland, California Adventure Park, Knotts Berry Farm, San Diego, Sea World, Tijuana, Las Vegas (yeah baby - my fave), San Francisco and finally 4 days in Honolulu, Hawaii on the way home :P
here's pics of my R34
Thanks for those pics. They look great.
I'll post an idea I had to make it even better. It involves some foam and some glue.....
dezz, not just yet.
I'm picking up the GTR and GTST prototype blanks on Monday and I will bend them up Monday evening.
Then I will borrow the cars of two nice R33 people Tuesday night or Wednesday night or sometime.
Once I'm happy with them, I will take photos and then ask for money.
I'll get everything organised first, including freight and packaging, which is a pain in the arse and takes bloody ages to pack each one!!!
But, as you can see by Nightcrawlers photos, the guides are worth the wait.
BASS OUT
yep no problems just thought he got his 1 and i missed the buy :)
where abouts are you located, id donate my car if you need it, im in hoppers crossing though, so im guessing ur on the other side of melb or something :D
but this is looking like good timing, by the time you have these babies ready to go my car should be registered :)
umm..bass I haven't received pm and payment method yet so far...is this thing still going?
thanks
Sky 34 : Its only starting, once BASS has the prototype made up and fitted, he will take pics and will ask for Money deposit,
we are all ancious as well... :ban:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
