Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
The following people should keep an eye on their mail box in the next few days.....
2BNVS
GTS-T V-Spec
ZXFIRE
wolverine
Lordsnipe
Alpine Stars
bilbo117
Sydneykid
Trick
Cooper
I'm on a list!!!
Cakes and pies cakes and pies! :sorcerer:
  • Replies 520
Hey guys.
Thanks for the pics, they look even better on the car!
I should be able to pick up the anodised guides today, so will finish shipping them all this week.
BASS OUT
I received my guide yesterday and it looks good!
I'm not 100% sure about how it fits though. Has anybody fitted theres to their Series II?
You can see from the pics that the guide sits right up against the bonnet latch. It's not too bad, you can still open the bonnet but I thought it'd come down a bit lower.
You can also see that when the bonnet is shut that the airflow to the air filter snorkel would be more restricted than what it was from factory?
Farkin.
On the Series II I checked them on at the SAU BBQ after Christmas they were perfect.
Is your front bar standard? Is anything modified?
Cheers
Pete
PS Freeman,
I was going to be a smarty pants and say "When I get your delivery address" but I just realised that I now have your delivery address, so your guides will leave today or tomorrow with the Anodised ones.
The Anodised ones are on their way to me right now.
Pics forth Coming.
heya Bass Junky,
I'm at work atm so I can't measure it up, I'll do it at home.
My front bar is stock except for a lip which has been put on before I bought the car. I didn't think the grille was anything aftermarket?
Here's a piccy...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
