Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Oh, Series I Stags and R33 Series II people, the folder hasn't done them on the weekend but promises them to me at the start of next week.
BASS OUT
  • Replies 520
BASS OUT
The start of next week (this week) has come and passed so has the folder kept his priomise or is it another week?
I spoke to him an hour ago and he hadn't done them. :(
So tomorrow I'm going there at lunch to use the machine myself to do them.
Hey Guys,
I have bent up all the R33 Series I guides, all the R34 Guides and the main panel of the Series I Stags.
The scoop of the Series I Stags is going to be this week.
The Series II GTS-T and the Series II Stag guides and scoops are on order at the new place and will be ready in a couple of weeks.
If I was able to refund the monies I would but I have to prepay to get this work done so the money is already in the parts.
BASS OUT
You already stated above that the SII GTST were to be folded by yourself coz the guy had not done them....now your saying they are on order at a new place.
Which is it...are they cut and unfolded or not even cut at all? It appears you're deceiving the people who gave you their money as this group buy was clearly not organised properly from the outset.
Darkboy.
I just looked back through my posts and I apologise.
I meant Series I stag and Series I GTS-T
Please accept my apologies.
I make no qualms that I have turned this group buy into a balls up.
I totally and unashamedly offer my apologies to everyone for the length of time this has taken.
As some of you know, during the group buy, I have changed jobs and this has reduced my access to easy design and supply of this things to virtually nil.
I am replacing all the first batch of R33 Series II guides because they are wrong which = money out of my pocket because of my stuff up.
I'm trying to do everything right, but unfortunely things didn't go to plan.
I WILL supply everyone with their parts and they will be as close to spot on as I can get them.
Next time I will do things very differently.
Sorry again,
BASS OUT
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
