:P Have R32 GTR. When I'm cruising with no boost, usually on freeways, I'm finding that when I accelerate to pass a truck or car etc. the car seems to slip, like the clutch slipping. The revs go up, then it grips and the revs go down.
So here's my delemma, why when I thrash the living hell out of it on 1.1 bar is there is no slipping????????
I have a triple plate clutch. Could heat in clutch be making it grip; or heat in Attessa system making traction work though the front wheels?
I have not changed the attessa automatic fluid for longer than I remember (IN fact never since i got it from Jap, bad hey, didn't know it was there till now. Done all other things). Can revs be lost in attessa system, sending torque to front wheels???
Any ideas anyone.....
https://www.sau.com.au/forums/topic/95432-attessa-or-clutch/
mine does that some times when i turn sharp corners that go up hill, i hear the wheels slip and the attessa needle goes up, and the car seems to bog down. But when i'm playing i don't realy notice the car bog down when the rears slip.
btw you stole my handle :P
what does the front torque gauge show when this occurs?
if it was loss of traction then it should bounce up a little when attessa transfers power to the front. but it sounds like clutch slip if its going up and then down a little.
This slipping that's accuring is not accuring under any harsh acceleration. It happens after being at the same revs for a while, usually while crusing on the freeway. Then when half throttle is applyed thats when it happens. There is no loss in traction because there isn't enough power.
Thats the reason i don't think it is the clutch. It usually doesn't happen a second time for a bit, till i cruise again and after 3 mins or so.
dude, i been around longer than u, savman is mine :( nah, my last name is savage, hence savman.
You could have 1kw and if the clutch is stuffed it will do what you are describing. Its something in the driveline between the engine and wheels thats slipping (hence the engine speed going faster than the car actually is), and the only real part in there that can cause these symptoms is a clutch.
If your clutch is wearing out, you will notice it slipping in 4th and 5th gear first. When mine was on the way out, it took about 3 months of driving around with 4th and 5th slipping for it to start slipping in 2nd and 3rd.
Exactly, it sounds like clutch. ATTESSA won't allow what you are describing, as the rear tailshaft is constantly driven via the gearbox regarless of what ATTESSA tells the front wheels to do. The only variable is the percentage of front drive governed by ATTESSA. So if she aint wheelspinning, the clutch is slipping!
:) Have R32 GTR. When I'm cruising with no boost, usually on freeways, I'm finding that when I accelerate to pass a truck or car etc. the car seems to slip, like the clutch slipping. The revs go up, then it grips and the revs go down.
The ATTESSA system can be disabled by pulling a fuse. Symptons of its failure are that there is little or no torque transfer forward - despite what the gauge is telling you. Mostly this will give you bulk oversteer - you should be able to feel the front wheels pulling the car back into line if the system is fully operational.
Unless you have a serious lack of rear end grip you won't be getting wheelspin in third or even fourth in a straight line. Which suggests clutch. To allay you fears about the ATTESSA system, get a mate to drive alonside & keep a lookout for wheelspin.
Just as a side note - I had my car feel like it was slipping once and it was a basic ATTESSA problem. The the boot of the GT-R's on the drivers side there is a little bottle inside a small compartment. That was below the minimum level line. I topped it up with ATF and the problem was solved. No harm in looking into that 1st.
I just had that yesterday. For about the last week, whenever I started my car from work (and only work - weird, perhaps coz I park in the sun and things were getting hot? Dunno...) my 4wd light would come on and wouldn't go off unless I turned the car off and re-started. I was at a driving arvo yesterday, and when i went out on the track I noticed that around all the corners my front torque guage was on 0 (it is only a sprint track, but still), and under acceleration the guage wasn't showing what it normally did. That whole run the car felt like a rwd.
Luckily I had stopped and bought some ATF (I got genuine nissan, just incase it was a special blend) on the way, topped up the reserviour in the boot as it was about 2 inches below the minimum line. Next run felt a little bit better and the run after that it seemed to be back to normal. The min and max lines are only 1cm apart though which seems a little....silly!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
