  • Replies 215
Posted Images
Dan i don't know if you've been told or have heard but Boaty is trying to get numbers up for a prctice on Friday night at Mallala. It's not gonna be a DA or SD only practice but for anyone who wants to. I belive Mallala is trying to have it on at 5-9pm on this Friday. If you can make it, I'd suggest calling Boaty and showing interest. Could be some VERY valuable prctice time for you!
Great news mate, congrats. It's all coming together now.
My mate and I will be driving there and towing his car. His name's Rob and he drives a white 180SX with a Cosmo 13B in it. F**king crazy.
Ah,,,Roto Power gotta love it.
Possum,,,just in the nick of time. So we both will have a great weekend. Poor Duncan he'll have to sit at home renovating Ha Ha Ha.
Neil.
Well Guys,
Car is painted, Everything is on bar the side skirts, do that this morning... Decals will be applied in a NOT WINDY AREA once we arrive.
Getting tune this morning and we are off... I can't believe that it is done, I am stoked... and the paint looks AWESOME!!!!
I'll give a run down on the last week when I get back... Until then Kids, Stay Sideways.
PS. Did I mention that the whole build has been documented for the documentary being made on me... so who would watch the program?
Dan.
PPS. Neil, have fun this weekend mate, and good luck!
Hey Guys... Well the build is I guess done... but I am thinking I might continue this thread while I develop the car also...
We had HUGE weekend... even if I did only do 15 laps all weekend... As Neil said, I qualified 8th, which was fantastic, and even though I was giving Denzo a hard time, I Spun and finished 18th... either way I am happy that I made it down, qualified, competed and brought back a working car!
Thanks for all the well wishes and support... I had a massive last month getting the car ready.
Don't forget to watch the footage on Speedweek on the 11th of June.
Cheers Guys,
Dan.
Pic Attached courtosey of www.speedshots.com.au
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
